When on the satellite mode the reviever will work in 2 different cars with different craddles I used to be able to press down on the top and it would come in for a secound.
SOURCE: Lost antennae reception
either the antenna is broken, or your service was cancelled. Contact SIRIUS for your account info. Did you pay to have the new radio turned on? I believe they have a $75.00 "activation fee".
SOURCE: Speakers on right side of car not working when satellite radio is
Try rewiring the system matey, you proberly need to daisy chain them together
SOURCE: can i use existing satelite antena on my audi
The antenna should plug into the Stilleto car kit if your Audi is equipped with Sirius already. Otherwise you will have to use another Sirius antenna.
SOURCE: Stilleto 2 keeps shutting down
It may be a problem with the power switch, I too had this problem. It seems like the power switch is stuck in "down" position as if you were holding it. I remove my battery cover (along with the battery) and gently jiggle the switch up and down to "loosen" whatever may be sticking it in place and it seems to work. I have encountered this problem several times. I did not send it out for repair. It works fine for me (knock on wood).
