Checked all external connections on unit and speakers. the unit is used in the garage, so I took the top cover off and blew all of the dust off of the internals (I only took the top piece off, I didn't dig any further)
SOURCE: No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
SOURCE: rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
SOURCE: "Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
SOURCE: Sony STR-D665
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back
and see if you get rid of protect state. Sometimes accumulation of
electrostatic charges inside circuit capacitors can kick in protect
mode. In that case unplugging the unit from main for some times can get
rid of electrostatic charges, and reset circuits by draining power
completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number
listed on the owners manual, or asking a quote on repair to a local
technician.
SOURCE: Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
