Our washer is not getting any further than sensing the load. It senses for about 15 minutes and then just shuts off. We have had it for about 1 year and have had no issues with it until now. Any ideas on why this is happening and how can it be fixed? Any help would be appreciated
Spring:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
SOURCE: Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being
a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using
a recent Maytag range it may pay to test the oven sensor as described above
as this may cause an F1 error if faulty (may apply to some other ranges as
well) this is not a common cause but is worth discounting.
To check the ERC and touchpad
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
SOURCE: I have an auto sensing load whirlpool washer,
is it still under warranty but anyway there is a water fill level switch that controls the water level and when it reaches the setting u have it on then it shuts the water off and the wash cycle kicks in most likely bad or it may have a small hose on it that is crinkled off or stopped up
