Question about Frigidaire AEQ7000ES Dryer
Frigidaire affinity front load electric dryer having problems, last night i used the dryer in quick dry mode and within 15 minutes left i opened the dryer door to check on how dry the clothes were, closed the dryer door back, and pressed the start button and it beeped with a message of pause under the 15 minutes and would not start back
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Moisture in dryer
you have a clogged vent, somehow your vent has become clogged either with in the hose, or where it exits the house, the moisture being removed from the wet clothes is not leaving the unit. CHECK YOUR VENTING POTENTIAL FIRE HAZARD!!!!!
Posted on Oct 26, 2008
dragonsthatk
albert getty
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
seth adams
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
franktalk
  • 193 Answers
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
Posted on Nov 10, 2009
Liza Timmers
SOURCE: iDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Posted on Oct 05, 2011
Frigidare affinity stactable front loading dryer. runs for 10 to 15 seconds then shuts off. plenty of exhaust air. it has heat inside. tried resetting to factory specs but still have the same problem
Good Morning Percy, thank you for your inquiry!
From the information you have provided you Frigidaire dryer runs for 10 to 15 seconds and then will shut off. It sounds like it could be a possible problem with your thermostat or control panel. A reset may help with any internal miscommunications inside of your dryer. You can reset your dryer by disconnecting power from it for at least ten minutes. If that does not help your issue I would recommend having a professional technician out to perform an accurate diagnosis on your dryer to avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Aug 12, 2015 | Frigidaire Affinity Series Stackable...
Have a affinity front load dryer that comes on runs five min then shuts off and all three lights by the start button come on and flash wont heat up
Hi Friend, this is Z. I appreciate your inquiry!
I interpret that you are having trouble with your Frigidaire dryer (FASE7073NW) not starting. Let's try resetting your dryer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dryer to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Aug 21, 2014 | Frigidaire Affinity FASE7073NW 27"...
My frigidair affinity dryer wont start it just beeps
Good Afternoon Friend,
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
MY FRIGIDAIRE AFFINITY FRONT LOAD DRYER THE PROBLEM IS IT WILL START DRYING BUT AFTER ABOUT 2-5 MINUTES A BUZZ SOUND WILL COME ON WITH THE E64
Hello Marcheller, thank you for your question! Typically error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Aug 15, 2013 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity washer FAFS4272LA0 is cutting on by itself with no lights on, the door locks, then when I turn the knob it says 0:03 draining.
there is a problem with the control board its possibly got wet at some stage or other I would take a hair dryer to it and try to dry it out and then try plugging it in again eric
Dec 27, 2017 | Frigidaire FAFS4272LA Affinity 4.2 cu. ft....
I have an Affinity Dryer that works for the first 5 minutes, exactly, then in flashes AD. It continues to spin but not dry at that point.
Problem is going to be with the thermistor located on the blower housing at the front. You will see 2 plastic pieces with wires going to them. The thermistor is the one on the left. Cannot jump this out all you can do is change it.
Mar 10, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Jun 27, 2009 | Frigidaire Electric Dryer
Dryer will work for about 15-20 minutes. Then shuts off. No heat in the dryer for my clothes to dry. The lights are blinking. Please help, we just got it last year. Thank you!
Always list your machine model, mfg, type, voltatge, etc. The more info we have the more we can help you. If you just got the machine, check your warranty. Blinking lights probably mean an electronic control problem, you're going to need a qualified tech to fix that.
Apr 24, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
94 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
