Question about HP Pavilion dv9008nr Notebook
No sound will not switch sound to headphones through headphone jacks
  • krantzke May 26, 2009
    I am using Windows XP Media Center on an HP pavillion dv9000 laptop. I have all the drivers updated and tried a system restore right after the problem ocuured. I was listening on headphones one minute and the next...nothing. the sound was now only coming out of the laptop speakers and not the headphones. The wireless is also not working, but I have already found that my computer is on the recall list for the wireless card.
  • Anonymous May 11, 2010
    What OS are you running, what type of computer, and have you downloaded all the latest sound drivers for your particular computer/OS combo?  If not, that is a great place to start.  Also, under sound properties (If a windows OS), sometimes things are muted - make sure nothing is muted in sound properties! :)
  • 197 Answers
Try to re-install audio driver
Posted on May 28, 2009
    Sergeant:
  • 239 Answers
Go to sound controls and see headphone sound is not muted...if its so then try to install new audio drivers....
Posted on May 26, 2009
  • Anonymous May 27, 2009
    see whether headphone sound is not muted in sound control menu.....if so install new audio drivers..
    check whether the headphone volume is not muted in sound control menu.....if its not den install new audio drivers....
6ya staff
SOURCE:
My headphone jack not work when i put it in my tablet i can still here the sound from my tablet and the headphones from the tablet it is a irulu Tablet,
Make sure you push the headphone plug into the jack completely. If you're sure that it is, then the jack on the tablet has failed. The sound gets switched from speaker to headphone in the jack itself.
Aug 08, 2015 | Tablets & eReaders
Why compucessory headphones not working
Did you plug them into the headphone jack or the microphone jack on your computer ? Usually those 2 jacks are next to each other and it is easy to confuse them. If this is not the problem, maybe the headphones have a switch to turn them on (this would be unusual, but you never know...). Hope this helps.
Nov 16, 2014 | Compucessory Audio Players & Recorders
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
Same problem as below, I have the Denon AVR 790 and the sound keeps switching to headphones. Blowing into the socket did not help. Both unpluging the AV and putting the headphones in and out fix's the...
The unit thinks there are headphone plugged in even when there are not. You need to have the headphone jack replaced. This is a common problem with this model. Another way to fix it if you don't plan on using the headphone jack is to unplug the cable going to the headphone jack board. This will disable the headphone jack, and stop it from sending an erroneous signal to the micro.
Jan 31, 2014 | Denon Avr-790 - 7.1 Channel Home Theatre...
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
Using headphones
You can get a set of speakers that has a headphone jack on front (it will shut off the speakers when headphones are in) or you can unplug the speakers and plug in the head phones. Some PCs have a red and green jack in front - plug in headphones to the green, you should have the speakers shut off till you unplug. All else fails they make a headphone/mic extender that sits like a hockey puck on the desk, has cables to the mic and speaker jacks on back of the PC and on the puck part has a jack for speakers, mic and headphone - some switched manually by you, some switch when the headphones plug in. If you had posted the model I could see if your machine has front red and green jacks.
Jun 19, 2010 | E-Machines eMachines Desktop PC
My headphone jack is broken on my Dell Latitude Cpx J & i have no sound through my speakers because of this. Is their a way i can change something in the settings so the sound plays through my laptop...
It is a mecanical problem, not in settings. The laptop's headphone jacks have builted-in switches that disconnect internal speackers when the headphone jack is plugged in. You need to replase headphone jack with a new one or manually desactivate the swith - must to get ino your laptop and have skills in work with soldiering iron
May 22, 2010 | Dell Latitude CPX-J Notebook
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
HP Pavilion dv9008nr Notebook Logo
129 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
