PS-3 via HDMI unsupported mode
SOURCE: HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
SOURCE: Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
SOURCE: HP-T4254 samsung TV turns itself off and on
Try this step before purchasing power supply. I have serviced this tv before. Lay it flat plug it in and it should turn on,but once you sit it up straight it will turn off. I think there are faulty fairchild mosfet transistors or a firmware issue. I put a 1 inch thick book under the stand so it tilts up or down. I have not had a call from any customer since.
SOURCE: vertical black line on Samsung HP-T4254
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
SOURCE: Samsung LCD TV LN40A550P3F will not support 1080
Hi, is the directv box giving out 1080? There is an option on the box to select between 480, 720, 1080.
Also the tv has the same option.
