Pleaser USA Jezebel614 5.75" Square Heel Ankle Strap Platforms Sandle for Women Logo
A
Anonymous Posted on Jan 09, 2014
Calcification I have calcification in the ankle how does it get treated. I have appointment to see specialist thank you
Jim Pattison
Level 3:
Master:
  • Master 1,004 Answers
  • Posted on Jun 03, 2016
Jim Pattison
Master
Level 3:
Master:
Answers
1004
Questions
0
Helped
279056
Points
1705
If you have calcification in the ankle, the treatment is to have a negative heel rocker put on your shoe to limit the motion at heel strike and possibly a postive rocker sole. A Pedorthist can help you get your shoes modified. A podiatrist (DPM) can give advice about the calcification and what is needed to be done to fix that.
Pain in the foot, ankle and calf
Hello, Kathleen -
If you would like to have an idea of what is causing your severe pain before you go to your primary physician and have your situation evaluated, I refer you to the well-respected health and medical website WebMD and its Symptom Checker:
https://symptoms.webmd.com/default.htm#introView
Please do not self-diagnose and make an appointment with your primary physician SOON!
Best wishes.
How do I stop my ankles and feet to swelling after being sun burnt
Hello Anne.
Since this is a Q & A about cars and trucks,,, I will venture off topic..
This is serious and therefore should be evaluated by a physician. When you go to your doctor's appointment, be prepared to discuss the following possibilities. If the ankle swelling started just after the sunburn, it may be due to an inflammatory reaction as the skin tries to heal. A sunburn is a first degree burn but it still causes local inflammation and pain. As the body mounts an inflammatory response, the capillaries in the area dilate and become leaky. This process can cause localized edema and swelling, which usually resolves on its own over time. However, not every sunburn causes this reaction, so if yours is severe, you should see a physician. The reason you get extreme pain when you stand still is because the blood is pooling in your lower legs causing the swelling to increase. It is so painful cause the tissues are ripping apart to create room for the 'blood pooling' or tissue swelling. The most sensitive areas are the shins cause the tissue is tightly attached to the bone. That is why when you sit down or lay down it subsides or goes away. The body is not "upright" causing gravity to pool the blood in your lower legs ankles and feet can also be due to lymphedema. Lymph fluid travels up through vessel and is filtered through the lymph nodes of the body. Any issue with the lymph nodes or vessels in your leg can cause the fluid to pool in lower areas of the leg. If you have ever had lymph nodes in your abdomen, pelvis, or legs removed or irradiated, you should see a doctor very soon. Another possible cause of your problem, is your body retaining too much fluid overall, which can be manifested as swollen ankles and feet. This condition, called pitting edema, can affect people who have problems with their heart, liver, or other body systems. When fluid builds up in the legs, it can also build up in the lungs and other critical organs, so it is important to have this issue evaluated immediately. I strongly recommend that you make an appointment to see your primary care doctor ASAP!!, and he or she can refer you to a specialist if this becomes necessary.
How can get rid of facial and body calcification bumps?
It has been studied as you say. Opinion on the causes does seem to have a faint air of guesswork in some cases, as do some suggested treatments. If you haven't already done, ask the doctor if blood tests might show a definite cause, as suggested here
http://www.geekloveshealth.com/causes-and-how-to-get-rid-of-calcium-deposits-on-face/
http://www.livestrong.com/article/30648-treat-calcium-deposits-skin/
Then you might want to ask a dermatologist about abrasive removal.
1helpful
Hey,i am a new patient infected with Tb of the ankle.I take my treatment as told by the doctors.Now, problem is that after taking it i feel sick,itching and pin like needles pock under my skin.
TB of the ankle? That is pretty rare, sympathies to you.
It's possible you are allergic to one or more of the drugs you are prescribed. Ring or call in to the doctor and leave details about this, and ask them to get back to you. Or make an appointment.
Good luck
2helpful
5answers
What is amlodipine
Talks about Anlodpine
Machine says CALCIF What does it mean?
CALCIF usually indicates "calcification" which is a buildup of calcium and other minerals. I don't believe you would normally see this indication on a microwave oven. Coffeemakers often indicate mineral buildup by indicating "DESCALE" or similar.
Descaling or removing mineral deposits in a coffeemaker usually requires running the coffeemaker with white vinegar instead of water, and no coffee ground or filter. Three or four "brewings" is usually all that is needed to remove the deposits. Simply run several more brewing cycles of clean water to rinse all the internal components of any vinegar and the job is complete.
If this answer isn't applicable - please tell me model number of the appliance that is displaying the CALCIF message, otherwise, please rate my reply "4 thumbs up" if it was helpful Thanks!
Top Pleaser USA Clothing Accessories Experts
ADMIN Andrew
ADMIN Andrew
john h
Don A
Don A
Are you a Pleaser USA Clothing Accessory Expert? Answer questions, earn points and help others
