Question about Kenwood KDC-215S CD Player
Kenwood wiring diagram
Lighting has burned out on removable panel. Can it be replaced? radio does work OK.
4 Suggested Answers
6ya staff
SOURCE:
justuscc
Jimmy
  • 360 Answers
SOURCE: radio does not work when key is on accessory
ok the batt wire is orange on the car and yellow on the radio. the accessory wire is yellow on the car and red on the radio good luck hope this helps ya rate as fixya thanks
Posted on Oct 01, 2008
Tim Swiercinsky
  • 1126 Answers
SOURCE: I need wiring diagram for Kenwood kdc-mp228 radio
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/
Just input your model number in the third search field, download the user manual, then look on page 25 for wiring connections. Hope this helps.
Posted on Aug 23, 2009
Anonymous
  • 12 Answers
SOURCE: I need a wirng diagram for a kenwood radio
Just visit the following website to download the manual for free. http://kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/
Ir is the blue and white PCONT wire.
Posted on Apr 13, 2010
Instrument nel lighting intermident
lot of work in replacing the instrument cluster panel lamps. you need special tool to remove the radio because some of the panel screws are in there. you will need to disconnect gear indicator and electrical harnesses from instrument cluster. you will also need to remove several panels as well. I have lots of experience doing this and it took me two hours. consider finding someone that does automotive work at their house. word of mouth is the best networking way.
Mar 11, 2014 | 1999 Ford Taurus
I have a '93 ford crown Victoria LX. The door panel lights a radio keep going out (fuse blows). And I have replaced the dudes at least once a day. I have used a 10,15,20,25, and even a 30 watt fuse, but...
Unplug the radio and see if it still blows the fuse. Try to isolate it to the lighting circuit or the radio. You have a bad short somewhere. Trying higher rated fuses may cause your wiring to burn up.
Nov 20, 2013 | Cars & Trucks
Set of three glomar track lighting purchased at home depot, one by one the lights burned out, when I replaced the bulbs, nothing happened, still do not come on, unit was taken to another location and...
well first if it worked some where else it is not the lighting, did you replace it with another fixture and diid it work, if not i would have an electrician look at your wiring to make sure it is ok
Sep 05, 2013 | Home
2001 Ford Ranger radio was working till a bad storm went over and the next day no radio or power to the radio
look at the ant mast and base for signs of burns if lighting hit the ant it will fry the radio
Jul 02, 2012 | Cars & Trucks
I have a multimiter DMM 8903. I made a mistake. I forgot to change from ohmeter to voltmeter.Was a small flame inside and de buzz started.The fuse was not burned. The display is showing ok. I opened the...
unhook any power source from the unit, if you can solder remove that part and take it to any radio shack , or place like that , who supplies electronic parts, and have them give you a suitable replacement , and re-install it,, be sure to check for board burns or bubbling in the line strips. this part is for one or more of the functions of your meter
Jul 12, 2011 | Square D 30 Amp Lighting Contactor W...
Dash lighting and tail light.
the bulb in the dash went out you need to remove cluster panel near where the light went out
Jun 02, 2009 | 2000 Mitsubishi Montero
Colorado Instrument panel lighting
The bulbs plug into a printed circuit board, I suspect they have come loose, pull the cluster and see if they are loose or burned out.
Oct 26, 2008 | 2006 Chevrolet Colorado
My front panel won't light up, how can I remove to keypad to replace bulb?
The "lights" below the buttons in the panel are LED's and are not replaceable, also they have a extremely long lifespan making it near impossible to wear out.
If the panel isn't lighting up, your printer has another problem, not burned "lights".
Jan 22, 2008 | HP PSC 950 All-In-One InkJet Printer
No front panel lighting
The "nightwatch" lighting uses an EL or electroluminescent material that does degrade with age. If the radio is old, then it may be lighting very dimly (check in a dark room with the dimmer at full bright). The material is connected by a ribbon to a special high voltage pulsed powersupply that runs at about 500 volt. If the power supply is working then a new face would be in order or a new radio. If the powersupply is not working it may be repairable but requires working with surface mount components. Either way, it is NOT a simple lightbulb fix. I have successfully repaired and do stock the smc components to repair but cannot get the faces through cobra ($$$). More info? Contact through www.cbshop.info
Jan 31, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Kenwood KDC-215S CD Player Logo
148 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
