Ps3 had ylod that has since been fixed. my problem now is when i turn the ps3 on it asks for the hard drive to be formatted, witch would usually just be a case of holding down the ps button on the control pad and hitting x. but thats my problem the ps3 wont recognise the controller its not lightiong up the wifi icon at the bottom of the unit. i tried the wifi board from this system in another and it worked fine so i think it must be the motherboard but im unsure. any ideas?
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
SOURCE: ps3 won't boot
The same thing happened today to mine so i rang sony. They said because i bought my ps3 when it came out as a good will gesture their sending a courier out to me to exchange it (In 2 days). Man I love Sony don't know about you guys. LOL.
SOURCE: My controller will not connect on my ps3.
Sounds like the controller knows it belongs to the other PS3. It has already "paired" with one console, so that's why you're having a hard time trying to get it to pair with console #2, comprende?
Make sure console #1 is a "hard off", like switched in the back. Now flip your controller over & put a pencil or pen tip in the reset hole. ( Just to the right of the center screw hole.) NOW connect said controller with the USB to console #2. Hold the PS button for two seconds. All 4 lights will flash 5 times, then the 1 light should stay on, Boo-ya! You're PAIRED!
SOURCE: hi after resetting my ps3 on system settings on
it sounds like your joystick won't pair up try turning on the joystick first then put the usb cord in
SOURCE: ps3 ylod
Oh.. no... you must fix your PS3 using correct methods instead of doing in the wrong ways. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
You can repair many other red and yellow light related issues by using this tutorials. After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
