Wifi password or the password for logging into the router settings? If you do a factory reset on the router it will put all settings back to default settings, the default password can normally be found on a sticker on the side or bottom of router. it will say "WEP" or "WPA2 key". you factory reset the router by holding down a red button (inside of a hole) on the back of the router for 12+ seconds while its still powered on.
SOURCE: Problem with netgear wgr614 v6 daisy chain
I am assuming the Verison was setup and working before this started, if not let me know.
Do you know the address and subnet mask for the lan side of the Verison Actiontec router? assumed like address 192.168.0.1 subnet mask 255.255.255.0 This means all addresses 192.168.0.? belong to the verison router's subnet.
Assuming the Netgear router is being daisy chained using a lan port from the Verison Router to the WAN port of the Netgear, the WAN side of the Netgear router needs to be either dynamically addressed or statically addressed in the 192.168.0.? uniquely outside the DHCP range for the Verison router.
The LAN side of the Netgear Router must not be addressed the same as the LAN side of the Verison router in this configuration.
There is another potential configuration where lan ports of both routers are connected. however in that configuration there are additional considerations. Please let ne know which connection you are attempting between the two routers.
There is some additional informatin you can gather
Assuning you have windows XP for the operating system on your computers hook a computer wired if possible to the LAN side of each router and issue the following commands
Click Start then All Programs then Accessories then Command Prompt in the new window that opens type the following command and press enter
ipconfig
write down th IP Address, Subnet Mask and Default Gateway for each adapter
Then issue the following command once for each default gateway not = 0.0.0.0 where {...} is replaced in its entirety with the default gateway.
pring {default gateway address no {}}
the expected responses will be either 4 timeouts or 4 lines with elapsed times. Timeout is failure -- elapsed times means it was connected.
For each router I need to know the default gateway and the subnet mask for the successful pair. Plese reply ina comment to this problem and additional steps will be forthcomming.
SOURCE: GT704-WG with Verizon firmware
For those with the Verizon version of the firmware wanting to setup a Slingbox... You can go to the Security tab and then go to the Games tab and setup the 5001 port from there. It works.
SOURCE: linking wrt54g with actiontec m1424wr
You need to check the ip address of your actiontec router, the default ip address of linksys router is 192.168.1.1, they should not be the same or else you will not able to connect the router to the internet.
To access the router web configuration
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3676&p_sid=fvzPHEYi&p_lva=3687#
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740145678B574
Let me also give you the site on how to add the linksys router to another existing router.
The linksys has 4 LAN port and 1 "Internet" port on the back - we ONLY use the LAN ports NEVER the Internet port - because your existing router is connected to the Internet - your linksys is connected to the LAN
http://www.kriyayoga.com/love_blog/post.php/368
SOURCE: can't log in
just ignore the * and type in the password blind.
the random * showing are to confuse the guy watching behind you, not you.
SOURCE: Actiontec GT 704 WG Verizon to Frontier
You will have to contact Frontier and give them the Mac address of the equipment and they will tell you if it will work or not ( and they will also need to put it in their system)
