A
Anonymous Posted on Jan 08, 2014
Subwoofer schematic diagram - Altec Lansing Audio Players & Recorders
shawn newman
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 16, 2014
shawn newman
Contributor
Level 1:
Answers
Questions
Helped
1559
Points
0
How do I hook up my subwoofer two a two chanel amp if the sub has two places on the back
tip
Schematic Diagrams for KLH ASW10-120
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
PSW 125 Diagram Schematic
download with model number suport e-manual pdf
[email protected] installed a 1984 engine in my 1975 CJ5 , I need to know how to connect the wiring for the ignition module
I just find this diagrams (click images for zoom)...
Fig. 5: 1975 Jeep CJ wiring schematic
Fig. 24: 1984 Jeep CJ and Scrambler 4 cylinder engine, wiring schematic
Fig. 25: 1984 Jeep CJ and Scrambler 6 cylinder engine, wiring schematic
Fig. 26: 1984 Jeep CJ and Scrambler wiring schematic, continued
Fig. 27: 1984 Jeep CJ and Scrambler wiring schematic, continued
Hope helps.
2answers
18 volt supply too low. resistor R42 burned. Q20 not installed. schematic shows 4700 ohm resistor with Q20 installed. What value if Q20 gone?
I would fit the same type, unless the schematic shows a change, which clearly it doesn't. However I would be surprised if R42 burnt up alone! Look at the schematic, is R42 linked to any other transistor or part? If so check them if you can.
By the way is R42 a fuseable resistor, for example is the symbol on the schematic or on PC board different to most other resistors?
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
