Microsoft Windows XP Professional Logo
A
Anonymous Posted on Jan 08, 2014
Mecer touch screen calibration - Microsoft Windows XP Professional
Bizhub 500. made a mistake during touch screen calibration. Is there any option to enter the screen calibration without touching the touch screen?
Select the Accessibility button ?
Option (1) Touch Panel Adjustment - Touch the four "+" buttons ? Press Start ? Close
2answers
How do I recalibrate the screen on a Bizhub 250?
Remove the Compact Flash Cover. Located Right side next to where the network cable is installed. Remove the cover, using a small screw driver or small plastic stick depress black button gently. Called the Warm Restart switch.
When "." appears at the center on the left-hand side of the screen, enter "3" from the via 10-Key Pad. Enter the 8-digit service code and touch [END]. (Default value: 00000000) if required.
Touch [Touch Panel Adjustment] from the Initial mode screen.
Following the arrow mark, touch the four points (+) sequentially on the screen using a pen. DO NOT USE A SHARPE POINT!!!!!.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Touch problem
Nokia designed the N97 with a touch-screen calibration program to remedy problems with the touch screen. Opening the touch-screen calibration program requires you to use the touch screen, which can prove difficult. You're forced to judge where to tap the screen because the screen isn't recording the precise location of your taps. To find the touch-screen calibration program, open the main menu, select "Settings" and then "Touch Input." The program provides on-screen instructions to help you finish calibrating the screen.
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
6helpful
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
7helpful
Calibration wizard.you have to calibrate the touch screen
calibration wizard. you have to calibrate the touch-screen mobile model No: JC 777s
4helpful
2answers
China mobile
have a china made handheld double sim touch-screen phone. The device is Winkoy T6688. The touch screen got damaged and after reseting the device, the following notice appears after turning it on:
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
Of course you can´t but there´s no other option because it won´t accept any other input until it´s calibrated apparently. Does anyone know how to bypass this calibration wizard on start up?
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
