Lost my security code and need to hard reset.
SOURCE: Resetting Security Code
hi freinds
i have nokia 1100 phone ane my imei is 35793000/200543/4 and i had for got my security code can some one help me to reset it and can you help to reset code for nokia 1100 phone
SOURCE: master code/security code reset
You didn't give the full IMEI. It should be of 15 digits. You provided 14 digit and possibly you forgot to mention another one digit.
as of mine losing security code a big problem the only solution for this, reformat the mobile to clear the old file.
SOURCE: hard reset nokia 6620
Turn off the phone
Press 3, * and the green call key together whilst turning on the phone.
It will ask if you wish to reset to factory defaults (this will erase ALL data from the phone), just follow the onscreen prompts.
The default security key is 12345, hope this works for you.
SOURCE: need master code or other solution to change security code
You can master reset your phone from the phone settings so that the security code changes to the default value 12345..
