Nokia 2330 GPRS and WAP / Internet Settings
You'll need to complete all steps for this to work.
The phone has a four-way directional Navi key and two soft keys on either side of this. The Navi key can also be pressed in to select options.
1.Press Menu (press Navi key)
2.Highlight Settings and Select (press Navi key)
3.Highlight Configuration and Select (press Navi key)
4.Highlight Personal configuartion settings and Select (press Navi key)
5.Press Add new (Navi key)
6.Highlight Web and Select (press Navi key)
7.Highlight Account Name and Select (press Navi key), enter giffgaff WAP GPRS then OK (press Navi Key).
8.Highlight Homepage and Select (press Navi key), enter http://giffgaff.com/mobile then OK (press Navi Key)
9.Highlight User name and Select (press Navi key), enter giffgaff then OK (press Navi key)
10.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
11.Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
12.Highlight Access point settings and Select (press Navi key)
13.Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
14.Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
15.Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
16.Highlight Bearer settings and Select (press Navi key)
17.Highlight Packet data access point and Select (press Navi key), enter giffgaff.com and OK (press Navi key)
18.Skip past Network type this should be set to IPv4
19.Skip past Authentication type, this should be set as Normal
20.Highlight User name and Select (press Navi key), enter giffgaff and OK (press Navi key)
21.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
22.Press Back three times (right soft key)
23.Highlight giffgaff WAP GPRS and press Options (left soft key)
24.Highlight Activate and Select (press Navi Key)
25.Press Back (right soft key) four times.
Please switch your handset off and back on again before using these settings.
The settings are now complete.
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this. The Navi key can also be pressed in to select options.
1. Press the 'i' button (press navi key).
2. Highlight 'Browser' and press 'Select' (left softkey).
3. Highlight 'Browser settings' and press 'Select' (left softkey).
4. Press 'Options' (left softkey) , highlight 'Add new connection' and 'Select' (left softkey).
5. Highlight 'Profile Name' and enter 'giffgaff GPRS WAP'
6. Highlight 'Homepage URL' and enter 'http://giffgaff.com/mobile'.
7. Check that 'Proxy' is ticked (press Navi key to tick/untick).
8. Highlight 'IP Address' and enter '193.113.200.195'.
9. Highlight 'Port' and enter '8080'
10. Ignore 'Linger time' (this is preset at 90).
11. Check that 'DNS' is unticked (press Navi key to tick/untick).
12. Highlight 'Bearer' and select 'GPRS' by pressing the Navi key right or left.
13. Highlight 'Advanced settings' and select using center Navi key.
14. Highlight 'APN' and enter 'giffgaff.com'.
15. Highlight 'Login ID' and enter 'giffgaff'.
16. Highlight 'Password' and enter 'password'.
17. Press 'Save' twice (left softkey).
18. Highlight 'giffgaff GPRS WAP' and press 'Options' (left softkey)
19. Highlight 'Activate' and 'Select' (left softkey).
20. Press 'Back' (right softkey) 3 times to return to the main screen.
The GPRS WAP settings are now complete.
