Kenmore Top Freezer Refrigerator Logo
M
MELVA JONES Posted on Jan 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HELLO I HAVE A KENMORE TOP FREEZER BOTTOM FRIDGE AND NEITHER IS COLD OR FREEZING. MY MEATS AND ICECREAM HAVE DEFROSTED AND BOUT SPOILED. IN THE BACK OF FREEZER WHITE ICE IS FORMING IN WHAT LOOKS LIKE
THERE IS SLUDGE IN THE BACK OF REFRIGERATOR WHERE A LIL GREY TUBE IS LINGERING AS A DRAINAGE I BELIEVE. I HAVE NO IDEA AND IM BEING TOLD $75 JUST TO COME OUT AND LOOK AT IT NO TELLING WHAT TOTAL COST MAY BE.
  • MELVA JONES
    MELVA JONES Jan 08, 2014
    I HAVE CLEANED FRIDGE OUT AND DEFROSTED THE BACK OF FREEZER WHERE ICE BUILT UP. I ALSO WENT INTO FRIDGE AREA REMOVED TOP COMPARTMENT TO CLEAN TUBING OUT. UPON DOING SO WHEN I PLUGGED EVRYTHING BACK IN NOTHING WORKED AT ALL AND THAT WAS SEVERAL HOURS AGO. MODEL NO. 253. 6080240G
  • MELVA JONES
    Add a CommentWHAT NOW? I AM DETEMINED TO DO ALL I CAN TO TRY AND AVOID UNNECESSARY COST TO A REPAIRMAN. WISH I COULD LEAVE MY NUMBER AND SPEAK DIRECTLY TO SOMEONE...LOL. OH WELL PLEASE HELPO. I SEE PART NAMES BUT I NEED TO KNOW WHAT THEY LOOK LIKE AND WHERE THEY ARE EXACTLY.
Michael Harrier
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 125 Answers
  • Posted on Jan 08, 2014
Michael Harrier
Expert
Level 2:
Cheetah:
Answers
125
Questions
0
Helped
25208
Points
275
Defrost and clean the entire fridge/freezer and clean out the grill and all the back and bottom under the fridge...with a vacuum..alot of times the fins in the back become coated in dust and cannot effectively cool the appliance..worth a try
4 Related Answers
Anonymous
  • 725 Answers
  • Posted on Sep 01, 2008
SOURCE: Kenmore Refrigerator Mod 70162990
It is under the evaporator you will have to remove the back cover... let me know if you want to do it and I will step you thru it...
Anonymous
  • 163 Answers
  • Posted on Mar 09, 2009
SOURCE: Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jul 01, 2009
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Anonymous
  • Posted on Jan 04, 2010
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Fridge is not keeping the food cold, water at the bottom of fridge, freezer is not as cold, still freezes things but takes a long time. This is a Kenmore 20 fridge, my guess is 15 years old.
unplug the fridge and leave the doors open for 48 hours, then see if your problem is gone 24 hours later after you plug it back in, if it is, your fridge needs to have a repair to the defrost side of things, most likely the defrost termination therm or the defrost timer, also make sure the drain under the evaporator is not plugged up
Top freezer works, but bottom of fridge is 65 and spoiled a lot of food.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
2answers
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
1helpful
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Refridgerator/Freezer will not get cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
1helpful
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
  • possible causes:
  1. bad defrost timer/board
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
6helpful
3answers
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Check to see if the refrigerator is clean at the condensor at the bottom or at the top of the unit. All fans running inside and outside the unit? Door gaskets sealing tightly. Put a dollar bill between the door gasket and cabinet and clost the door. Slight drag ok. No rsistane, bad gasket. No solution at this point, call for service.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
