IT DOES HAVE DIAL TONE
SOURCE: Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
SOURCE: manual for panasonic kx-tg5240
Here's the manual (Adobe PDF) from Panasoni's site:
http://service.us.panasonic.com/OPERMANPDF/KXTG5240.PDF
SOURCE: set number of rings
First press the menu button then scroll up or down to "initial setting" and press the select button. then select the set answering option then select the number of rings option now you can select the number of rings by scrolling up ^ or down. or you could just press the number on the keypad. Once you have selected the amount of rings you want press SAVE, then press off and your all set.
SOURCE: Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
