A polar bear's skin is actually black. It's black so it can soak up as much of the sun's rays as possible. Polar bears have almost transparent fur over black skin. Reflection of the sunlight from the densely packed transparent hairs makes polar bears seem to be white. The bears' black skin absorbs heat from the sun. The seemingly-transparent fur is made up of hollow hairs called guard hairs. These air-filled guard hairs help transmit heat from the sunlight to the polar bear's black skin as a solar heat collector. In turn, the reflection stops the heat being lost from their black skin. Reply if you have any more questions. Good Luck, Cooper. (Please give a good review, I am doing this for a summer job!)
The best skin and hair combination will be people with darker hair and lighter skin. It's the color contrast that is mosly important. The laser energy is light, and light absorbed better by dark objects.
If the hair is light (blond) and the skin is dark (tanned), the light will not be absorbed at the hair follicle, but rather by the skin melanin, causing a burning of the skin, and damaging the melanin production in the skin cells. That's why white and gray hair, which contain no pigment, are not effectively treated by laser.
Hi I also have blonde hair and fair skin. I recommend using Nars blush in a pinkish color and different brown hues on your eyes (but not heavy). Keep it light!
It depends on the aviator type you mean, since you have two: 1. http://www.smartbuyglasses.com/designer-sunglasses/Ray-Ban/Ray-Ban-RB3026-Large-Metal-II-Aviator-L2846-16200.html 2.http://www.smartbuyglasses.com/designer-sunglasses/Ray-Ban/Ray-Ban-RB3250-Aviator-OO471-16213.html Both frames would look good on almost everybody, although you should be careful with long faces. In that case, the second frame might not look perfect. In addition, you should ensure that the frame color suits the hair and skin color; a golden frame might look very good on somebody with a tanned skin and black hair, while it would absolutely not suit somebody with a white skin and blonde hair. Source(s): www.smartbuyglasses.com
When I turn it on the screen turns white. The screen is all screwed up. I can still listen to music, I just can't see the menu or tell what anything says
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Yes now yahoo upgraded their system..... it avatar reader can read the color codes...as it's reading the color is matching it will say...and define depend upon color code....
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps. Andy
