SOURCE: problem in dos application
hi
change your resolution to 800x600 or 1024x768 resolution.
then right click the c++ exe then go to its property and go to screen enable the full screen. now u get the c++ editor in full screen.
kishor.
SOURCE: graphics devlopment
sorry vishu Micro Soft Vista is not going to support full screen DOS mode in any mean.
Thanks
Iqbal
SOURCE: how can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
Displays a list of commands.
add
Adds a configuration entry to a list of entries.
add helper
Installs a helper DLL.
delete
Deletes a configuration entry from a list of entries.
delete helper
Deletes a helper DLL.
dump
Displays a configuration script.
exec
Runs a script file.
help
interface
Changes to the `interface' context.
ip
Changes the 'interface ip' context.
ras
Changes to the `ras' context.
aaaa
Changes to the `ras aaaa' context.
appletalk
Changes to the `ras appletalk' context.
ip
Changes the 'ras ip' context.
ipx
Changes to the `ras ipx' context.
netbeui
Changes to the `ras netbeui' context.
routing
Changes to the `routing' context.
ip
Change to the 'routing ip' context.
ipx
Changes to the `routing ipx' context.
set
Updates configuration settings.
machine
Sets the current machine on which to operate.
show
Displays information.
show alias
Lists all defined aliases.
show helper
Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
Goes up one context level.
abort
Discards changes made while in offline mode.
add
alias
Adds an alias.
bye
Exits the program.
commit
Commits changes made while in offline mode.
delete
dump
exec
Runs a script file.
exit
Exits the program.
help
interface
offline
Sets the current mode to offline.
online
Sets the current mode to online.
popd
Pops a context from the stack.
pushd
Pushes current context on stack.
quit
Exits the program.
ras
routing
set
show
unalias
Deletes an alias.
Examples
netsh
Enter the netsh command.
netsh dump
Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command.
set address name="Local Area Connection" source=dhcp
Set the "Local Area Connection" to DHCP.
set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1
Set the local address to Static.
netsh interface ip show config
View network ip configuration. Below is an example of what may be seen.
Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
SOURCE: dos commands in linux
Ooohh. A command line fan!
Here's some basic commands for you
cd -
Go to previous directory
cd
Go to $HOME directory
(cd dir && command)
Go to dir, execute command and return to current dir LS Linux version of dos's DIR Dir will ALSO work though.
FDisk Manipulate the partition tables
CP copies one(or more) file to another location
Eject Ejects cd/dvd media
Exit Leaves the command line goodness, and returns to GUI
Man Important reading for linux newbies
MkDir make new directory
MV move or rename files and folders
rm delete a file
Rmdir remove(aka delete) directory
Umount unmounts a device("safe removal" for thumb drives)
