Nokia 3230 Logo
Anonymous Posted on May 25, 2009
Transfer files into memory card
I have Nokia (NYSE: NOK) 3230, Whenever i sent some music files from other phone to my nokia 3230 through Bluetooth Device. My phone shows a message "Memory Full, Please Delete Files Firstly". But i have 500 MB Memory Card, I noted that bluetooth files saved in Phone Memory not in Memory Card. My phone memory is only 5 MB. Anybody can tell me how can i change my bluetooth files path from phone memory to Memory Card during connectivity with another phone.
Anonymous
Level 3:
  • Master 311 Answers
  • Posted on May 25, 2009
Anonymous
Master
Level 3:
Answers
311
Questions
0
Helped
194209
Points
1267
Hello
for that you need to open message and then go to options nad over there you will find message setting
you have to change all incoming message come to you memory card not to your phone memory
Nokia 3230 formatted. mp3 transferred to mmc. but when switch on mobile, the mp3 cant be found on mobile.
just easily format your memory card thru your phone,needs a system file coming from the mobile,,,after that,locate the music folder were the music ors song is to be loaded.
May 03, 2011 • Nokia 3230
I cant send music files to it via bluetooth it keeps telling me to delete memory and now ive deleted everything and it still wont let me send music files via bluetooth. I have a nokia navigator 6110
make sure that all of the files that you have sent before via bleutooth was move on your memory card.take a lokk at your phone memory on how much is the free space.because once you transfer file via bluetooth it uses your phone memory. check your inbox outbox and myfolders.delete or move the files that is in there.then try to send via bluetooth again.hope I explained it well.
2answers
NOKIA 3230 with RS-MMC card 512 mb.
scan the mmc with the good virus scanner
Oct 31, 2009 • Nokia 3230
Please follow the below steps:
Open Messaging -> Options -> Settings -> Others -> Memory In Use.
Then change memory in use to memory card and files that you received will be save in the memory card
May 29, 2009 • Nokia 3230
My phon software (nokia 3230) is down it shows me that my phone memori is to low but I try to delet massages and other things from phon memori but nothing hapends .Whwt can I do?
hi tharaj here , when i am here no fear , its very easy to solve ok , the thing is ur 3230 got 5 to 6 MB phone memory so u should use memory card memory instead of phone memory , whenever you recieve data from b tooth save that in to memory card or els transfer from phone to memery card by using file manager ,still if if u face problem just press *#7780# and it ask code press12345 then think ur problem has solved , ok take care bye
Mar 07, 2009 • Nokia 3230
1helpful
How i can transfer files by bluetooth device from pc to mobile
u have to use first bluetoothsoil in your pc and power on the bluetooth onyour set then move files via bluetooth to your set if it does not work then call me +919906650824
My Nokia 5310 Express Music phone wont let me put music on, HELP!
I think your problem to your phone is chage the memory card ksi bka ewan ko..?
2helpful
Change memory used
Message memory can't be stored to memory card.  You can save them to your computer using Nokia PC Suite and either a data cable, bluetooth, or infra red interface if you phone and computer have them.
Only music, pictures, video, audio files, and software can be stored to the memory card.
Sep 10, 2008 • Nokia 3230
2answers
Can't get any music or files sent to my nokia3110 via bluetooth
Hi lizzy2,
I am sure i know its solution.
There are 2 types of data storages in mobile phones. One is phone memory and another one is MMC.
In NOKIA s60s, all files sent via bluetooth is sent to the inbox.
But ur NOKIA is type of s40. i Think, so ur all music or files sent to ur mobile via bluetooth is received in ur folder "received files" in phone memory in gallery !
I m sure check out ur folder "received files". 1st go to gallery, and see there r many folders such as sounds,video clips, memory card, received files, themes. Go to that "received files" folder, and there is ur required files.
looking for ur kind feedback.
I m Sajan([email protected])
If need help, just send me feedbacks.
May 04, 2008 • Cell Phones
17helpful
6answers
Music Player: Not enough memory to perform operation delete some data first
nthing to worry change ur message setting ,put memory card memory as memory in use. after cahnging tht u cn easily save ur files to ur memory card
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
