Sylvania SRT2232S 32" TV Logo
A
Anonymous Posted on Jan 07, 2014
Srt2232x weight how much does it weigh have a cabinet that only holds 80lbs
Top fin aquarium stand...29-36 gallon...doors on base cabinet will not stay closed
30 gallons of water weighs 300 lb and then there is the weight of the aquarium itself and accessories - that is a lot of weight that is likely to distort even a robust cabinet if it isn't standing on a perfectly flat and level floor, the most common reason why cupboards, cabinets and chests of all sorts never seem as good at home as in the shop.
Another possibility if the unit arrived as a flat pack, perhaps the attention to detail during assembly was less than precise...
Jan 01, 2019 • Fish
JC Higgins model 20 shotgun weight
Weigh it by differential process - weigh yourself. Then weigh yourself holding the gun. Subtract that weight from the first one and there you are.
Apr 26, 2018 • Firearms
Model 27. How much does it weigh?
A model 27/127 coincidentally weighs 27 pounds (12 kg), plus the weight of its motor, treadle, or hand crank, its light, and its case or cabinet. Such a weight strains the meaning of the term 'portable', even when fitted with only a hand crank and minimal wood case. Singer Model 27 and 127
1helpful
2answers
How do I find out the weight of my 42LC2DB television for a wall bracket
If its not on the paperwork get your bath scale have some one hold tv and stand on scale. note weight put down tv back on scale note weight and subtract,
I am assuming it's not a 60 inch, if so maybe 2 people and 2 scales
mike
2002FOREST RIVER WILDWOOD T25
You can take it to a truck scale to have it weighed. Your owners manual will give the trailer weight before you loaded it with camping equipment and kitchen ware. It weighs more than "off the showroom" floor weight....I'll bet. Good Luck....fill the holding tanks ...then go weigh, or look up capacity of your holding tanks and then multiply the gallon amounts X the weight of one gallon of water. Which is 8.35 pounds. And gasoline is 5.8 - 6.3 pounds. diesel = 7.15 pounds. Propane = about 4.11 pounds.
Mar 10, 2015 • RVs
How can I weigh my dog, it will not hold still on the scales?
This is really easy! Weigh yourself alone, then weigh yourself holding the dog, then subtract your own weight from both of you's weight. You can also ask your vet to weigh your dog for you.
Do not have a problem (yet)....what it would like to know...any idea how much a RCA 32" Stero Monitor Color Track Plus weighs...am looking to get a cabinet for it and need to know about how heavy it...
I Can only give you a ball park on this one, I have a Sony stereo Wega 32". It is bulky and weighs between 60 and 75lbs. if your going to add other components to the cabinet make sure you take the total weight into consideration
26helpful
2answers
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Nitrous bottle weight
20 pounds is what it holds, what the bottle weighs depends on what it is made of. A steel bottle and an allumnium one will weigh completly different but still hold the same amount.
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
