This is only the second time a DVD has been inserted in the DVD player, but after the TV screen said the DVD loaded and I hit play, nothing happened. So I tried to eject the DVD and it would not push the DVD out. There are two little plastic white pieces at the opening of DVD slot that will not move. Help!
SOURCE: SAMSUNG dvd
pushed info button on remote and held for 5 seconds. irritated it was so simple yet not listed any where on sites or manual.this was for samsung VR330 dvd player not tv.
SOURCE: Red color appear on my Insigna TV
This most likely a problem with the back lights and inverters circuits.The back lights may be receiving low voltages from the inverter circuit causing the led's not to function correctly. This needs to be tested by someone who can check the inverter circuits for correct voltage levels and the backlights for proper functioning.This usually has to be done in a service center.Try this website for Help and possible repair. LCDParts.net. Technical support telephone number is : 1-877-870-0581 or 1-415-682-8635 Hrs 9am to 5pm P.S.T. This site has lots of information on these type of problems. Hope this helps you with your problem.
SOURCE: The DVD player won't work; it spits the the DVD back out
If it is a burnt dvd, it might not play that format. If it isn't, I would take back the tv to where you got it from and get your miney back.
SOURCE: dvd player is playing in black and white on new
could it be the DVD player is european or simply set to output PAL or SECAM and not NTSC?
About the time plasma and LCD TVs started to replace classic CRTs pretty much all CRT TVs used to be able to handle both PAL/SECAM and NTSC.
Then, whether because of the difference in handling them due to switching to fixed display resolution or because of other considerations, less and less LCD and plasma TVs are handling all encodings.
So an older TV could have actually handled the encoding while a newer one lacks it, thus resulting in B/W image.
SOURCE: My husband inserted a dvd
#1 TRY AND UNPLUG THE UNIT. I HOPE YOU DIDNT BUY A TV/DVD COMBO.. THESE ARE WICKED $$$ to have fixed.. if it is never ever use the built in player ever again ! buy a stand alone unit from wamart for a few bucks and if it goes bad they fit well in the trash,.. so if it still isnt responding the back of the tv needs to come off WARNING if you break the screen the tv is junk, so sett it on a good flat spot , remove back, locate dvd player and un plug it from the tv.. this will take it out of the circut and with luck give you back control of the tv..
jay the pool pump whisperer.. longwood florida, buy USA made products THANKS AND VOTE if i was of help or coment...j
