I cant instal windows 7 on np-rv510 Samsung laptop during installation process when windows asking you on which partition you want to install system I have a message that I cant instal windows on this partition that I need to check the bios settings for sata but there is none and I cant find the hard drive controller for the hdd the only one on Samsung support web page are the one running from windows imsm which is exe file help
SOURCE: I Lost 20gb from my 160gb harddrive
Also the 160 GB rating is raw data, a fair chunk of that ?missing? space is being consumed by the operating system when it formats the hard drive.
SOURCE: Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
SOURCE: I am using ASUS P5RD1 VM 0604 series motherboard
SOURCE: I'm trying to wipe my hard drive with Fedora 12
Jeff what you have to do is this dont disturb yourself just go straight off the system then later on it and press your key F11 down at a time simultaneously then it will bring the system recovering factory settings for you and follow the instructions then you are through is just that all you have on the system will be gone but you will have your system back alive the way it was manufacture to work BYE THANKS
