When I tried to power on the TV today nothing happened. No green light or anything. I unplugged the TV for a few minutes and plugged it back in and still nothing. I tried using the remote as well as the power button on the TV.
SOURCE: tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
SOURCE: no sound, no picture. tried unplugging and
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
SOURCE: Magnavox MODEL # HD1905 C121
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
