The fan bearings are worn, it is best to replace them. As a temporary measure you can insert a small drop of oil on the bearing, the bearing can be accessed by carefully lifting the label in the center of the fan.
Flashing blue light is harmless - it simply means the Identify button has been pushed. There is a small button with a white, cursive 'i' on the front and back of the server - pressing this will make the light flash blue (or make it stop).
Go to Dell's support site and view the manual for the 1650 for an explanation of the beep code - identify the pattern of the beep.
If you are still able to get to Windows, use OpenManage Server Administrator to check the Hardware logs and RAID array.
