Hi, I have a problem with my projector. When trying to run the TV remote is included only sound but no picture after a few seconds turns off the sound. Before we had this problem TV is turned on normally and then started to not include any time now and did not want to include. A click is heard. Resembles the sound of a relay or switch. I would appreciate if you give me some guidance what could be the problem and how to be solved.
SOURCE: Sony Wega 42
Sounds like the bulb popped up... does it smells like there something that burned? any error light?
SOURCE: Is is worth getting repaired?
Power supply mnay be out. Yes, get an essimate if you like first, but if it's less than 8 years old-get it fixed.
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
for any friends who is looking for optoma projector color wheel, DV10, HD20, HD70, HD70i, etc, please freely contact me, i'm a professional wholesaler and net retailer on projector spare parts, most of brand and all series, lens, color wheel, bulb and remote.
Jack
[email protected]
