Not a real technical solution but if the original battery is still being used then there is a chance the battery is not holding the charge. I've had this issue in the past with a Motorola Droid and after the battery was replaced it held on for a few days instead of a couple of hours. Depending on phone use and charging methods older batteries will not hold a charge for long. I would recommend trying to get a battery saver app from the Google Play store to see if it helps as well. Again, this isn't a real tech solution but I hope this helps you along some. =)
SOURCE: correct procedure for charging battery
Batteries no longer have a memory problem so charge away. I plug mine in every night and have never had a issues.
SOURCE: Phone wont finish powering on - stays on 1st rumor screen
golf - the firmware needs to be flash on teh phone so take it to amobile service center and have that done.
may - the phone needs to be reflash on the phone
SOURCE: phone dropped in bathtub, screen says emergencey download
wrap it real tight in a paper towel...it works.
SOURCE: my voyager's inside screen has gone black
do the buttons on the inside work? if so maybe you dammaged the video cable to the screen. if the buttons do not work then the phone isnt recognising that you have opened it. does the external screen go blank when you open it?
SOURCE: LG Renoir Battery issues
My renoir has just developed this issue.
I have tried 2 batteries, tried re-flashing the firmware (even tried a
custom firmware) and nothing.
I am buying another battery to see if i were unlucky with the battery I
bought.
This does not appear to be an uncommon issue as I have found several
threads online regarding this. No definitive answer as yet.
