Polaroid P3500S Id Card Printer System Logo
A
Anonymous Posted on Jan 07, 2014
P3500S printer showing ribbon is out when it is not
There is an error showing the printer is out or missing code 110, but it is in place
Hiti P310W error 0100. Give solution
That is a very demanding question. I guess you mean "Does anyone have the answer to this error message please"?
Error Message And Corrective Action - HiTi Digital P750L ...
ManualsLib https://www.manualslib.com > ... > User manual
When the error happens, error message will be displayed on LCD of the operation panel. LCD Message. 0100 Cover Open. 0101 Cover open fail. 0200 IC Chip Missing.
HiTi P310W
HiTi https://www.hiti.com > files > Product > P310W...
It can cause a fire, electric shock or printer problem. Do not place the printer with dust, sand and high humidity such as bathing place, bathroom, hot spring, ...
14 pages
Missing: 0100 ‎' Show results with: 0100
HiTi P310W
HiTi https://www.hiti.com > P310WUserManual_all
case of irrecoverable problem, please contact HiTi dealers or service center. Page 5. English. HiTi P310W user manual. Chapter 1. Important Safety Instruction.
157 pages
HiTi P310W Passport and ID Photo Printer by HiTi
Amazon.ca https://www.amazon.ca > HiTi-P310W-Passport-Photo...
HiTi P310W Passport and ID Photo Printer (Ribbon/Paper Not Included) - HiTi 1 Year Limited Warranty; Printing Method: Dye Sublimation; Resolution: 300dpi ...
How can I fix my HiTi S510 for the error of Ribbon Missing
If you're experiencing a "Ribbon Missing" error on your HiTi S510 photo printer, here are some steps you can take to troubleshoot and resolve the issue:
  1. Check Ribbon Installation: Ensure that the ribbon is properly installed in the printer. Open the printer's cover and verify that the ribbon is securely inserted into the printer's ribbon cartridge or holder. Make sure it is correctly aligned and positioned according to the printer's instructions.
  2. Clean Ribbon Contacts: Over time, dust or debris can accumulate on the ribbon contacts, preventing proper communication between the printer and the ribbon. Use a clean, lint-free cloth or cotton swab lightly dampened with isopropyl alcohol to gently clean the contacts on both the ribbon cartridge and the printer. Be careful not to apply excessive pressure or damage the contacts.
  3. Reset Printer: Try resetting the printer to clear any temporary errors. Turn off the printer and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This can help reset the printer's internal settings and potentially resolve the "Ribbon Missing" error.
  4. Replace Ribbon Cartridge: If you have access to a spare ribbon cartridge, try replacing the current one to see if the error persists. Sometimes, the ribbon itself may be faulty or incompatible with the printer, causing the error message. Make sure you are using a genuine HiTi ribbon cartridge that is specifically designed for your printer model.
  5. Update Printer Firmware: Check if there are any available firmware updates for your HiTi S510 printer. Visit HiTi's official website or contact their customer support for information on firmware updates. Updating the firmware may address known issues or improve the printer's functionality, including proper ribbon detection.
  6. Contact HiTi Support: If the issue persists after attempting the above steps, it's recommended to contact HiTi customer support directly. They have access to specific troubleshooting steps and can provide further guidance based on their knowledge of the HiTi S510 printer. They may be able to diagnose the issue remotely or recommend further solutions.
When contacting customer support, provide them with detailed information about the issue, including any error messages or specific symptoms you are experiencing. This will help them provide more accurate assistance and advice tailored to your situation.
Note: Always follow safety precautions and consult the user manual or contact the manufacturer's support for specific instructions and guidelines related to your HiTi S510 printer.
I have a fargo HPD 5000 and I am getting the error 91 stating the ribbon is out..i have changed and its still showing the same error. am I doing something wrong?
Hi Camille - that is indeed the error message for "ribbon out". This has a few possible causes:
1. Make sure you have the right ribbon for the printer. The standard color (YMCK) ribbon is #084051; if dual-sided, the standard YMCKK ribbon #084052; if monochrome/black print only, that is ribbon #084060.
2. Make sure the ribbon is loaded correctly. The spools are color-coded, so make sure the orange on the ribbon spool is in placed with the orange on the carrier - ditto for the blue.
3. Make sure you've changed the "ribbon", not the "film". The ribbon has orange and blue spools; the film has yellow & green spools.
4. Make sure the ribbon is loaded properly on the carrier - it goes the "long way" around the carrier, across the silver/metal rollers.
5. Try another new ribbon - they're RFID tagged, and occasionally an RFID tag is bad, missing, or corrupted.
6. Verify you have the latest printer firmware, to ensure all ribbon manufacturing site-codes (embedded in the RFID tag) are recognized as valid for your printer.
If you have continued problems, we can help with further support, including potential repairs. Good luck!
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
How do i clean my printer after I change the ink roll?
What does this mean? "ink roller". I''ve never have never heard the term. Does you mean ink ribbon roll? Why would you need to clean anything with that type?
2helpful
My Hp colorlaserjet 37ooDN is showing the error : 59.C0 Pl. HELP
59.C0 Error Displayed on Control Panel Remove all the print cartridges from the printer so the right swing guide will be visible and check for the parts described in the photos below.
If the right side swing guide does not go all the way back, the 59.C0 alienation error will be displayed on the control panel. A plastic part on the swing guide could be missing.
See photo below where the three circles are on the right side of the printer.
Figure 1: Right swing arm assembly
37001See photo for details of the part. Call-out 1 in the photo below shows the parts in place, while Call-out 2 shows the missing part. (The part looks like an upside-down t.)
Figure 2: Missing part causing 59.C0 error
370021 - Part in place
2 - Part missing
Another cause for a 59.C0 error can be the black sliding lock is broken, out of place, or missing the spring. (See figure below) This can cause 59.C0 errors or 10.92.XX errors.
Figure 3: Right swing frame assembly
37003Replace the swing guide. Please look for the missing part in the printer so it will not cause other issues from movement to other parts of the printer.
If the part in the call-out is present, close the door slowly and observe the right side swing arm. It should close uniformally with the left side swing arm. If not, arrange for service on the printer and replace the right swing arm.
1helpful
2answers
Zebra 105sl printer shows Error Code: ribbon out Printer Idle: 60-16-3z after we moved it from a different location. However, we've been printing fine w/o ribbon for many years.
so u used the direct thermal label that doesn't need a ribbon ? check the driver at Printer & Faxes on the PC, change the print method on the printing preference from thermal transfer to direct thermal
2helpful
2answers
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
6helpful
2answers
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
1helpful
2answers
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Top Polaroid Office Equipment & Supplies Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
