Have 2400 Mk2 and have problems with modulation on USB and LSB on AM ,FM and the PA modulation is perfect on transmission I have tried other mics and turn modulation pot down and seems worse and a little better when turned open.I cannot find any info on the Superstar 2400 Mk2 PC board number PCMA 032A any where on the net Please help Thanking you
Here is a link for the owners manual
http://www.radiomanual.info/schemi/CB/CB_SuperStar_2400_user.pdf
SOURCE: trying wire a superstar dm-452
Hello bubba, the wiring code for the radio is
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
If this is the power /echo mic like it looks to be from the Workman catalog, then I can't remember what the wiring code is for the mic. I do know, that the audio wire has the ground/shield wire wrapped around it.Could be just about any color. Put the shield on pin 1 and the audio wire on pin 2 and all you have left should be 2 more. If you get it backwards, then the radio will key up as soon as you turn it on. You'll have to key it to hear the speaker. Just reverse the 2 on pins 3-4. Hope this helps as it's been over a year since I've seen one. Let me know,,, Mechanic
SOURCE: manual
http://safemanuals.com/user-guide-instructions-owner-manual/SUPERSTAR/CB%20RADIO%20SUPERSTAR%203900-_F
SOURCE: Wat ar FM,AM,USB,LSB.CW. On a CB radio
FM - Freq. Modulation
AM - Audio Modulation
USB - Upper Side Band
LSB- Lower Side Band
CW- Morris Code
Okay for those that is following ! I have sorted out AM and FM modulation but is still doing the "distorting""crackling" thing on LSB and USB I have send e-mail to the suppliers of this rig to see if I can get a circuit diagram.
