Konica Minolta magicolor 2400 Laser Printer Logo
A
Anonymous Posted on Jan 07, 2014
Not responding v1074
The ready light is blinking, the printer window says it is sending data to printer, but nothing else is happening
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jul 02, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913080
Points
11959
6helpful
ERROR 5B00 IP2770
How to Reset printer canon ip2770 (E 5B00) ip2770.jpegIP2770 Resetter v1074 I have tried. IP2770 Resetter was sent by our friends in Jambi, and hopefully this iP2770 Resetter runs perfectly. Resetter is free passwords ... and FREE
How to Reset Canon IP2770 Error 5B00
Download Canon iP2770 Restter v1074 free pass Here
(Do not forget to turn off the download manager, for a successful download)
Go to the iP2770 Service Mode:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
V1074 iP2770 Resetter Then run it:
1. Prepare 2 blank paper in the printer
2. In the menu "Clear Ink Counter" click "Play" and "Platen"
3. Click Test Print ... Done ...
(In some experiments sometimes "platen" unable / err message appears, but no problem, still can work well)
Hopefully Successfully
3helpful
2answers
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
1helpful
Kyocera FS-1020D lights blinking but doesn't respond
Fuser error (6000 error)
Contact your Kyocera Mita dealer.
Unfortunatly there is not much You could do Yourself
This error means that the fuser is either damaged or not connected properly to the rest of the printer. If its connection error You could try to fix it but in most cacses the fuser is just broken ie. overheated due to not enough air flow.
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
1helpful
Dell 1700n Ready/Data light blinking (secondary fault)
Ok, try this--1.power off printer 2. open front door 3. press and hold continue and cancel buttons 4. power back on 5. wait until light sequence stops om error 6. power off and back on.
this resets factory defaults on the printer..
Printer will not respond
Canon S330 Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Your printer should respond as normal
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Laserjet 5L Hangs on Single Sheet Input Jobs
This probably means that the document you printed is set to manual and the printer is waiting for input
try this:
print the document, when the data light is on, press the button on the printer, does it print? if yes go into word and under page setup set the printer to "Auto select" for the paper tray.
or remove paper, print, when the data light comes on, insert the paper into the single sheet tray
hope this helps
thanks for rating
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
