without phone model - I can give you vague solution but here goes
find apps. in spanish it will be most likely be aplicaciones
find settings could be Ajustes in Spanish
system - Sistema in Spanish
look for Idioma e introduccion in Spanish
then look for idioma in Spanish
change from Espanol to english
You need to use the remote to go to the setup menu and set the language to English, or if you are in the USA set it to US English, which is different from English.
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
If you can make your way to the main menu, select settings, (whatever that may be in spanish, sorry!), then go under languages to select English. I had to have a rep. from the company I have my phone thru to do this for me.
