Sony Playstation 3 (PS3) Console Logo
Posted on May 24, 2009
Need help with wireless router and wireless verison card.
I need to know how to get my myNETGEAR 3G Mobile Broadband Wireless Router to work with my Verizon Wirless internet. (Do not have username or password for my Verizon account).
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Jun 22, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
17225
Points
33
You need to bridge your modem first before you can use your netgear wireless router. You can reconfigure your netgear without bridging your modem and it will work, but the connection will not be as stable. You'll only need your Verizon password and username if your connection type is PPPoE. If your connection is DHCP, you don't need your username and password anymore, but you may have to ensure that your connection type inside the netgear router is set for DHCP as well. If you're a PPPoE, then you don't have to worry, even if you don't know your username and password, you can give Verizon a call and they will reset your password and give you your username after you've verified your information with them so you don't have to worry about anything. Whatever issue it is, they can help you with it. I suggest you have them bridge your modem first before using your netgear. If I know the brand and model number of your modem with verizon I can definitely give you instructions here on how to bridge your modem properly. Just let me know.
2 Related Answers
conejockey
  • Posted on Jun 17, 2008
SOURCE: how to connect to 3g mobile broadband
Yes you can! After 10 days of trial and error I finaly cracked this problem on sunday. Since then I've had several lag free hours on COD4 and RFOM with smooth play and no dropped connections. Now I'm not a techie but I will explain the best I can. I use 3 mobile broadband. First open your Network Connections. You will see the 3 modem, ignore this for now. Further down you will see 2 ethernet connections, Local are connection, and 1394 connection. Right click one of these and Bridge the connection. Then open the properties of your 3 modem and under Advanced click on internet connection sharing. Install your ethernet cable from the back of your computer directly to the PS3. On your PS3 network settings search for the new connection. On testing it should work. Hey presto your online. I use win xp on my system and it usualy works fine. Sometimes you get a DNS error, keep retrying, if no luck, restart your pc, connect your 3 service and you should be good to go. Hope this helps, good luck
Anonymous
  • Posted on Jan 26, 2010
SOURCE: Connecting my PS3 to the internet using a 3G Verizon Broadband
If your computer has built in wireless, set up a private wifi network and connect your ps3
How to install a Wireless-N 3G MIMO Broadband Router
What are you trying to connect with ? A laptop? What kind? What OS are you using? If it's connected correctly and you can access the internet with a Ethernet Cable attached to the Netgear and the computer, it may be a computer wireless issue.
My mother recently got a zyxel wireless router, didnt realise that her computer had no wireless adapter so she went and got a portable wireless network adapter and installed it. Turned on the router but...
First you need to decide what type of broadband and Internet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with the DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
F7d1301 v1 connect to internet
SETTING UP A BROADBAND CONNECTION
3helpful
2answers
How do I set up a wireless router on my computer?
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
I need help hooking up wireless internet
If you use a wireless router with the DSL or Cable Internet service and your laptop has a wireless card then you can also connect to the Internet at WiFi hot spots like McDonalds, Star Bucks, the Airport etc.
How to get wifi
First you need a WiFi wireless card or an USB WiFi adapter.
This will allow you to connect to a free WiFi hot spot location such as MacDonalds, Starbucks etc.
If you want to setup your own wireless network at home the you need a wireless router and then configure the wireless card/adapter in your computer with the router's wireless settings.
First you need to decide what type of broadband andInternet service you require and these are -
3. A wireless 3G network which uses the mobile/cell phone network and can beseparate or combine with your cell phone account
Note - Combined services generally offer discount pricing and may include amodem/wireless router.
If you use a wireless router with the DSL or Cable Internet service and yourlaptop has a wireless card then you can also connect to the Internet at WiFihot spots like McDonalds, Star Bucks, the Airport etc.
If you use the wireless 3G wireless broadband service, then you can access theInternet anywhere where your ISP has 3G wireless coverage. You need to checkthe service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to checkwith the various Internet Service providers to see if they can offer and thecost of the various plans.
Note the download limits and the associated additional costs if you exceed themonthly download limits. Once you sign up with a Internet Service provider,their documentation will include setting up instructions and/or installationCD.
My router dlink i 1604 5 ports cannot connect to the internet need help
First you need to decide what type of broadbandservice you require and these are -
Note the download limits and the associated additional costs if you exceed themonthly download limits. Once you sign up with a Internet Service provider,their documentation will include setting up instructions and/or installationCD.http://www.fixya.com/support/r6165994-setting_up_broadband_connection
I just bought this router and am trying to get it connect with a Verison wirelss USB mobile broadband. How can I connect it to my computer and an Xbox 360?
For Verizon i found that Currently, the DIR-412 Mobile Broadband Wireless Router is the only D-Link router that is 3G compatible. The DIR-412 supports 3G USB adapters complying with HSUPA/HSDPA/EV-DO/TD-SCDMA networks and works with most major cellular carriers (AT&T, Sprint, Verizon, Rogers, Telus, Bell, etc).
D-Link routers empower gamers to easily connect their Microsoft Xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and Xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft Xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to Xbox Live.
  • Click here to upgrade your firmware.
  • Click here for Xbox Live setup instructions with a router.
  • For Xbox Live support, please visit www.xbox.com.
  • If you need more help come back.
    Post / thumbs / testimonial are welcome!
    Need my USB sprint card to connect with my wireless G router
    Well - you are mixing up two different kind of wireless networks.
    Your sprint card connects to the same network a cell phone connects to (EV-DO technology), while your local network at home uses a different technology (802.11).
    What you need in order to connect to your Linksys router is a USB adapter like this.
    If you have any more questions, just come back here and leave a comment - I'm happy to help.
    Wireless network using usb modem
    First thing that you have to do is to check if the wireless light on your linksys wrt150N is lit. If it is, then that means that it is emitting wireless signal so you can connect wirelessly.
    Then, install your verizon usb mobile broadband card on your desktop. When you plug it to the usb port, a pop up balloon would show on your page which would say FOUND NEW HARDWARE. you could click on it and choose the CD-drive to install OR you can run the cd and have it install on itself.
    After installing the usb, try to connect to your wireless network. Start > Connect to > and then click on the name of your wireless network.
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
