Question about Black & Decker 14.4v Cordless Lithium Drill/driver
Won't charge fully
Problems with Black & Decker 14.4v Cordless Lithium Drill/driver, the battery no longer charges all the way and runs down in less than a minute.
  • 44 Answers
If your warranty has expired, you're best off buying a new drill. Replacing batteries will quickly add up to the cost of a new drill.
I know they cost a lot more, but, if you want something that will last a lot longer, look at a Milwaukee, DeWalt, Makita, Bosch, Hitachi for your replacement. Milwaukee actually guarantees their LiIon batteries will last 1,000 charges or longer.
Posted on May 24, 2009
6ya staff
SOURCE:
Why wont my black and decker 7.2 lithium drill take a charge ?
Did you check if the battery holds the charge? Also, you should verify the charger's output with a voltimeter.
Oct 26, 2015 | Black and Decker USA Black & Decker...
How do I re-charge by Black & Decker 12v cordless drill?
If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
Oct 04, 2014 | Black & Decker 12v Cordless Drill/driver...
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Black & Decker Black and Decker 18V...
Black and decker drill runs slow
Its much more likely that your batteries are not charging up properly. Ni-CD batteries suffer from 'memory effect' and can appear fully charged when only 70% charged. Also they lose charge when being stored. Do not short them out to discharge them! Wait until the drill complains that they are flat and then recharge them rather than when they first start to slow down. Do not let become completely flat (less than 1 volt).
Mar 03, 2013 | Black & Decker Black and Decker 18V...
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
How do you know when a black and decker battery's life is over
Normally when it will no longer hold a charge, that is, no matter how long you charge it, the battery goes flat very quickly. This happens sooner with Ni-Cad batteries than with Li-Ion.
Nov 19, 2011 | Black & Decker 18 Volt Cordless Drill...
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
Black and decker 18v cordless is not fully recharging
If the battery is less than 2 years old, Black & Decker/Dewalt has a 2 year warranty on all batteries from date of purchase. Its most likely just a bad or damaged cell from not being fully charged pre-purchase. What happens is most Ni-Cads are only given a trickle charge in the factory and if left on a shelf too long can fully deplete itself, causing irreparable damage to the cells. If you're outside of that, a cheaper solution for battery replacement would be to look into a battery cell manufacturer like Interstate battery, who sells a non-describable battery for pretty much any application for about half the price of a name-branded one. Funny thing is they use the same exact cells. Hope that helps.
Feb 07, 2011 | Black & Decker 18V Cordless Drill/Driver
Lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
Apr 26, 2009 | Black & Decker 18V Cordless Drill/Driver
Black & Decker 14.4v Cordless Lithium Drill/driver Logo
356 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Thomas F. Schneider
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
