The system turned itself off during a game of Fifa 14.It will not turn on.Ipress the on switch and it turns on then turns itself off.Aflashing red light is there until you put it in standby.
SOURCE: system shuts off and turns to red light standby
Hello. You may want to double check your connections and cables. The only time I've ever heard a clicking before a system shut it's self down was when a kid had stuck the battery cover from a TV remote into the disc drive.
Also, if the PS3 keeps acting like that, Sony will repair/replace the unit for free including shipping since it's under a year old. Thanks and good luck!
SOURCE: red light flashing/won't turn on
you are right about replacing the thermal compound between the cpu/gpu and heat sync. the gpu and cpu may need to be refolowed also. another tip is dont over tighten the screws. Tip: keep your ps3 flat do not keep it standing. when it is standing and heats up the thermal compound can start to move away from the heat sync. Keeping it flat will help extend the life PS3 at least from the overheating issue.
SOURCE: ps3 turns itself off with flashing red light
Hi My name is Juan and I have one solution for you for now don't do anything even if it stay on for few minutes or you could loose all of your data in your hard drive you have heard about the xbox360 red ring of dead well this is exactly what is happening to your ps3 for now is dead but it can be fix by reflow the VGA chip it is very important to do this with an equipment that is controlled by computer and I do this type of work I am an ebay trusted power seller so don't worry let me know if you want to send your motherboard in to fix it or buy another motherboard I do sell motherboards also
[email protected]
SOURCE: my ps3 suddenely turned itself off mid-game.
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
SOURCE: My PS3 just shut off during game play and now the
Over heating issue easily fixed look here http://www.slashgear.com/complete-ps3-problem-list-172513/
If the
system turns on but then turns itself off, beeps at you and flashes its lights
at you then you have over heated the system. The GPU chip has problem pulled
itself away from the board. This will require you to disassemble.......
OR Click here to download repair guide
If the
If the
system turns on but then turns itself off, beeps at you and flashes it's lights
at you then you have over heated the system. The GPU chip has probly pulled
itself away from the board. This will require you to diassemble the PS3...
If the
better u download repair guide....
click here to download repair guide
If the
itself away from the board....better u download repair guide its more useful...
If
the
lights
pulled
PS3... this kind of problem u can fix by using repair guide
easily...........
