Thanks for your question.
A blood pressure reading of 131/76 is pronounced "131 over 76." You may also see it written colloquially as 131/76 bp.
In a blood pressure reading of 131/76, 131 is called the systolic number and 76 is called the diastolic number. Systolic refers to the part of the cardiac cycle in which the heart contracts and pumps blood from the chambers into the arteries, and diastolic refers to the part of the cardiac cycle in which the heart relaxes and allows the chambers to fill with blood. You may also hear the systolic and diastolic numbers referred to as the top number and the bottom number.
Systolic and diastolic readings are measured in mmHg, which is a unit of pressure equal to the pressure that can support a column of mercury 1 millimeter high. Hg is the chemical symbol for mercury. For a blood pressure reading of 131/76, you would pronounce it "131 over 76 millimeters of mercury
The systolic pressure was determined but afterwards the cuff pressure fell below 20
mmHg. This situation can occur if the tube becomes unplugged after the systolic blood
pressure has been measured. Check the tube connections and repeat the measurement.
Further possible cause: No pulse could be detected
A normal systolic blood pressure is 120 or below. A systolic blood pressure of 120-139 means you have normal blood pressure that is higher than ideal, or borderline high blood pressure.
It's pretty high on both ends. If they are both close though, it can not be a terribly bad story though. 120/80mmHg is typical normal values. Be sure cuff is at heart level and stationary when measuring. Systolic is crazy high.
110/95 Blood Pressure Is 110/95 Good Blood Pressure or High Blood Pressure?
There are two parts or two separate numbers referred to as blood pressure: Systolic/Diastolic. If the blood pressure is 110/95 (110 over 95), it means that the systolic pressure is 110 and the diastolic pressure is 95.
110/95 blood pressure can also be read as 110/95 mm Hg, or 110/95 millimeters of mercury. The 110 mm Hg Systolic refers to the pressure in the arteries when the heart beats, and the 95 mm Hg Diastolic is the pressure in the arteries between heartbeats.
When determining if 110/95 is a good blood pressure, we looked at the American Heart Association's blood pressure chart.
Blood Pressure Systolic Diastolic
Normal
Less than 120
Less than 80
Prehypertension
120 - 139
80 - 89
High Blood Pressure
(Hypertension) Stage 1
140 - 159
90 - 99
High Blood Pressure
(Hypertension) Stage 2
160 or higher
100 or higher
Hypertensive Crisis
(Emergency care needed)
Higher than 180
Higher than 110
For 110/95 to be good, both numbers must fit into the "normal" category above. Otherwise, it will fall into other categories of High Blood Pressure.
Systolic reading of 110 is in the Normal range.
Diastolic reading of 95 is in High Blood Pressure (Hypertension) Stage 1 range. Therefore, 110/95 is High Blood Pressure (Hypertension Stage 1).
There's 2 numbers that make up your blood pressure. The top number is called the Systolic pressure. The bottom number is call the Diastolic pressure. When a blood pressure is taken, it's measuring the pressure that the heart is producing when it pumps blood through the arteries. For example, what's considered a normal blood pressure in a healthy individual is in the range of 120/80. Of course age, life style and other health conditions, play a role in what yours may be. A person with High blood pressure or Hypertension would have a blood pressure of over 160 - Systolic and over 90+ Diastolic. 90 is actually the borderline for hypertension. That's why I indicated 90+.
The other reading on your monitor is your heart rate or pulse rate. It's how many beats your heart completes in one minute. It also indicates an irregular heart beat by the showing a small LED window on the left of the screen adjacent to the Systolic pressure reading, It will say IHB. Any movement or shaking or talking during the measurement can result in pulse irregularities. So hold very still when taking your blood pressure. This irregularity by itself is not of much concern, unless it shows up frequently. In which case, you should seek medical advice.
That covers just about all there is to know about what the readings mean. Armed with this, you should be able to effectively monitor your blood pressure and pulse rate and report them to your doctor.
Hope I was able to help you understand how it works and what it's telling you. if so, please let me know, by rating my response to you. Thanks and have a healthy day.
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
