When I play any movie, the white side still the same. The other half seems okay but kind of blurry.
SOURCE: AKAI LCT2662N screen problems -distorted
that sounds like your LCD controller, since the LCD screen is so big, they will "split" the screen into 2 smaller screens, otherwise it would be so outrageously expensive to have one big massive lcd controller. Your lcd controller is most likely a two-in-one card though, meaning that there are 2 controllers on one board. You'll more than likely need a new controller card for your tv.
SOURCE: LG Flat Screen TV has no picture, but sound
The times my TV at home has done this it is because I'm tuned to an HD source and my TV doesn't have HD. Or vice-versa, I tune to a regular channel and I have the TV set to HD.
If you have NO picture, like the channel number or volume bar don't appear, then this isn't the problem at all.
I would say check the Video (Yellow) cable in the back, or try setting up and playing a DVD and see what happens. maybe cycle through video modes, Digital etc.
If none of this helps, comment on the post and we can exchange more information.
SOURCE: My TV screen is only
It sounds like a loose flex cable that connects one module to another...I would find a local shop to check it out
