Ok, I realize this machine is already EOL, but if anyone else runs into this issue, I found the answer here.
Press the "Utility" button
Press the "Access" button
Press * four times
Press the "Maint" soft button on the touch screen
Press the "Service Mode" soft button on the touch screen
Once you are in there, you can reset the admin password by pressing the "Administrator # Initialize" soft button, and that will reset the admin password back to the default 00000000. This is actually for an IT3640, but evidently, this works for a few other models of NEC copiers as well.
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
• Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
I looked through the service manual for this and I see "tech rep mode" listed. I don't think you can access this from your digital screen, but look for it. Other than that it suggested opening the "front door" and closing it again with the power on to reset. Hope this helps. If you manage to access the Tech Rep mode, there is a button to press to reset the machine...
Hi TECH REP MODE IS NOT 12345678 0R 00000000 THESE ARE TO GET INTO ADMINISTRATOR PASSWORDS TO GET INTO ADMIN TO GET INTO TECH REP MODE YOU HAVE TO PRESS UTILITY KEY METER ON DISPLAY DETAILS THEN STOP 00 STOP 01 IN THIS ORDER ONE AFTER THE OTHER THIS WILL TAKE YOU INTO TECH REP MODE... HOWEVER THIS MODE IS FOR TRAINED CERTIFIED TECHNICIANS ONLY AND IS NOT FOR USE BY HAVE A GO DIY PEOPLE ENTERING INTO THE TECH REP MODE MAY CAUSE DAMAGE BEYOND REPAIR TO NO CERTIFIED TECHNICANS YOU HAVE BEEN WARNED GET TRAINED FIRST
1.press the utility button
2.meter count and details button
3.enter tech rep mode: stop,0,0,stop,01
4.select tech rep choice mode
5.select printer tab
6.select atdc sensor gain
7.set value to 165
back out to the ready screen then power off then on the machine have done this many times and just fixed one today with the same problem
It is the elevator malfunction.For reset press the trouble reset switch on the tech.rep.setting switches board or open and close the front door or turn OFF and ON the main switch.
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode: 1. Press the Utility key. 2. Touch Meter Count. 3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1. 4. Select Tech. Rep. Mode.
C12CX (X is any value)
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode. Go to "Counter" Go to "Trouble" Trouble reset If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar. You may need to clear the counter by pressing "clear" and then "end". After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
