Question about Technics SL-1210 Turntable
No Power to turntable
I am getting no power at all to one of my technics turntables. It is a SL1210mk2. I have tried changing the fuse in the plug but still nothing happens when I turn it on. Is there a simple solution?
    New Friend:
  • 135 Answers
A totally dead SL1200 / 1210 is usually just down to a blown fuse on the power input circuit board which is under the platter and the sub platter cover.
It is marked "F1" and is a timelag / 250mA / 20mm type.
Posted on Jul 05, 2010
  • 28 Answers
Why not try replacing the whole power chord with new one instead of just changing the fuse ( but you will have to splice the two wire lines at the end of your turntable console if not to resolder it, and be sure to properly mask it with an electrical tape to avoid electrical hazard/shock to anyone... ;-)
Posted on May 24, 2009
6ya staff
SOURCE:
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
My 1210 was working fine the other day, my daughter was playing around with it turning it on and off but nothing too harsh. I went to turn it on today and there is no power what so ever. How do I change...
Your turntable may be plugged in to a "switched" power outlet on your receiver/amplifier. If it is, your amplifier needs to be on for your turntable to get power.
Apr 26, 2011 | Technics SL-1210 Turntable
Plug in sldz 1200 no power tried another cord same no power changed out fuse with same amps and volt from radio shack still no power so im stuck help please.
You need to use a ohm meter (you can get one cheap) and find out if the power switch is working. You can also determine with it if the power is getting into the turntable. If the switch is working and power is getting to it, then either the transformer has failed or something is wrong in the power supply section.
Dec 02, 2010 | Technics SL-DZ1200 Turntable
Won't turn on, plug fuse changed but no power on. is there a fuse inside? many thanks chris
The most obvious cause is the power switch might have broken. Most turntables open from the bottom, so just go in and look!
Jan 27, 2010 | Technics SL-1210MK3 Turntable
Me technic 1210s wont *** on ive tryed change in the fuses wiv 1 from tv an still nothing any ideas?
It could have got an internal fuse, not the one in the plug. Also the power switch might have broken. There's only one way to find out! Take the bottom off and have a look.
Jan 12, 2010 | Technics SL-1210 Turntable
No power when i turn on my mk3 turntable
Check the internal fuses. There are two. You have to strip the unit down to get to them.
This video will show you what's involved:
http://www.youtube.com/watch?v=CDYgjwdQ55s&feature=channel_page
Aug 17, 2009 | Technics SL-1210 Turntable
Stopped working
No! I meant trying another wall outlet. If you do not have a meter to check the power then try another plug. The motor will usually have some hum or noise if there is power to the motor. Steve
Feb 08, 2009 | Technics SL-1200 Turntable
Power failure
First check to see if your turntable has fuses installed on the main PC board, which is located underneath the turntable platter. They should be easily visible once you remove the black protective cover underneath your turntable platter. Check them out first to see if they are blown, if so, replace with equal rating fuses. If you don't see any fuses, or the fuses look fine, then your power transformer has gone out - this is the grey metal box looking thing next to your PC board. This would need to be replaced. Parts for this model can be purchased HERE - just pick your turntable, and that's it!
- DJ PRO LAB
Feb 29, 2008 | Technics SL-1200MK2 Turntable
International Power
You have probably permanently damaged your turntable. The voltage supply in Germany is 220V AC, whereas in the US it is 110 V AC. It is just possible that all you have done is to blow a fuse in the unit, if no external fuse holders are visible then try opening up the case and looking for one near where the power cable enters the unit. If you have no luck with that then the transformer is almost certainly burnt out - this could be replaced but it is unlikely to be something you can do yourself. Please don't plug anything else that is designed for 110V into a European socket, regardless of being able to get an adaptor that will fit the socket - the voltage is different. It will almost certainly die as well and the possible risks of electric shock, fire etc. are quite significant. Hope this helps, if you want to try and get the unit repaired in Germany please ask again with details of your location and I will try and find you a reputable repair facility. If in doubt about which of your items can be plugged in in Europe then please ask as some can be switched to deal with the higher voltage, although not all. :)
Jun 25, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1210 Turntable Logo
423 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
