Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Diane Harris Posted on Jan 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool refridgerator side by side is leaking water on the side. We do not know where it is leaking from
Bruce
Level 2:
Scholar:
  • Expert 145 Answers
  • Posted on Jan 08, 2014
Bruce
Expert
Level 2:
Scholar:
Answers
145
Questions
Helped
70593
Points
172
Often water leaks result in stains on the Stainless Steel, use DeBruce Polish for removal. Using DeBruce Polish on all your stainless steel will allow you to now perform JUST TOUCH UPS of finger printing and remove the need for "OILS" that manufacturers provide for cosmetic care of blending. Stainless IS A GREAT FINISH TO CARE FOR one just needs the right product. Once cleaned with DeBruce Polish there exists no oil or other "films" to BLEND. DeBruce Polish will now perform touch ups instantly. LOVE YOUR STAINLESS STEEL AGAIN! Get DeBruce Polish at debrucepolish.com NON-TOXIC AN ODORLESS ...PERFECT
4 Related Answers
tom weber
  • 198 Answers
  • Posted on Jan 05, 2009
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Anonymous
  • 999 Answers
  • Posted on Aug 10, 2009
SOURCE: Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
mt2ri
  • 3 Answers
  • Posted on Jan 11, 2010
SOURCE: ED2KVEXVL Whirlpool refridgerator - not cooling in refridgerator
Tip: Most self-defrosting household refrigerators that loose part or all of their cooling in the freezer or fridge are having problems with the self-defrost system. Three components to check: defrost timer; defrost heater elements (esp. on side x side units); and evaporator fan. All cold air is normally produced in the freezer, then circulated via evaporator fan to the refrigerator section. About every 12 hrs. a defrost timer turns off the compressor, and turns on the defrost elements to melt the frost from the evaporator coils. This normally takes about 20 minutes to complete, then the timer turns off the heaters, and restores normal cooling operations. If the cycle does not complete properly, the coils will "ice up", restricting proper air circulation through the freezer and refrigerator sections. Worse yet is if timer sticks in defrost mode (rare), it will turn the freezer into an oven. If the defrost system seems to be working normally, then you should check the condensing coils for excess dirt, and vacuum &/or bush the dirt and lint out to restore proper head disipation. It's recommended that you vacuum out a condensor that's located on the bottom of the unit once a year. You should also check the condensor fan (if present) for proper operation. If the condensor fan fails, heat can not be properly released from the condensor, and will cause the refrigerator to 'run all the time' yet not cool efficiently. There are many things to check on modern frost-free refrigerators, before turning to the actual sealed refrigeration system and compressor unit.
BOYNISMO
  • 120 Answers
  • Posted on Jan 24, 2010
SOURCE: whirlpool refridgerator is leaking water on the freezer side
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Water leaks
Need more information
Does the refridgerator have plumbing for water/ ice? Is the water connected? Check that fittings are tight and not leaking.
How old is your machine? Older refridgerator have a drip pan in order to be frost free. Drip pan could be not in correctly or the hose from compressor is not flowing to drip pan.
Is the refridge level?
Whirlpool refridgerator with top freezer. Water leaks and pools at bottom of refridgerator under crisper. How do I fix the leak?
Here is a Utube video that will do the trick. Might not be your model, but same gig.
https://www.youtube.com/watch?v=VHD556AQ894
I have a whirlpool refrigerator Model GI5SVAXVL01. (2 door upper- Freezer on bottom). SN K01668079 About once a week there is a puddle of water on the floor right front side of refrig. I cannot tell where...
After looking carefully at the exploded views of this refridgerator
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GI5SVAXVL01/1198/0161000?pathTaken=&prst=0&shdMod=GI5SVAXVL01
I believe your problem is caused by a leaking hose or fitting for the water dispenser
Pay close attention to items # 11 and 19 on the diagram labeled Refridgerator door parts
Try turning off the water supply to the dispenser and see if the problem is resoleved... if so you know thats where the problem is
I own a whirlpool gs5shaxnl refrigerator that has
Hi Slick;
You have to take off the front dispensor mechanism and clean.. Be Very Very carefull as these are common for breaking.. It is hard to explain how to repair without having it in front of me.. hope you understand..Cheers
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
1helpful
2answers
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
side by side ice and water in the door?open both doors and remove the bottom grill.on the left is a drain pan.is it full or mostly full?the condensor fan motors are known to give out gradually.they may run for a day and not the next two.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
