see the block diagram attached. Unplugeed the machine, and tight every connector going to the display panel. Starting by ribbon cable inside from display board.
2) Reset the machine see your instr. manual for to see where is located the r. button.
3) Test the fuse inside the machine and replace if necessary.
4) Test the REED switch, see the diagram attached, test if for open or defective, clean it, and tight very well the connector, and Try again.
God bless you
