Question about Proscan Televison & Video
Proscan how to
Need to reset but keep getting error message.
I have a Proscan Flat Screen TV Model PLEDV2845A. I want to connect my Philips HTL2101A Sound Bar.
I have intially connected both via Coax cable as the soundbar does NOT have HDMI port. I then went into the setup on the TV to Sound, set sound to PCM
Initially it worked fine. 2nd day it will not won't work. Per instructions from Philips I have upgraded the firmware on the SoundBar.
Any ideas
Posted on Jun 04, 2014
6ya staff
SOURCE:
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
Jan 23, 2018 | Tablets & eReaders
The sound volume keeps going all the way up and wont stay to a normal level I have a32 inch proscan flatscreen tv
See if resetting the electronics to factory defaults cures the issue. If not, get some ear plugs till you have the main board replaced.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 23, 2017 | Proscan Televison & Video
Factory reset
Factory reset Proscan PLT 70330 use power and volume buttons to reset.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Factory Reset on Proscan PLT7223G or Tablet
How to reset proscan tablet model PLT7033D to factory setting its locked
want to reset my PIN on my Proscan PLT7033D
Mar 23, 2016 | Cell Phones
How do I get the message unfortunately com.android.phone off my sons proscan tablet?
Have you tried the reset with the paper clip in the reset hole yet.?
I think the reset hole is on the back. Press gently into the hole with a paper clip.
You will lose all data however and it will go back to factory default settings.
This is a common problem with Proscan tablets. Make sure you charge the battery fully before starting.
Jan 08, 2015 | Tablets & eReaders
Why do my proscan tablet keeps resetting its self
Not normal behaviour. You should take it to service
Dec 28, 2014 | Proscan 8" Tablet with 4GB Memory
Proscan plt8816k
trying to download but keep getting a note saying "no app found to open url". what should i do?
Nov 23, 2013 | Proscan Recertified - PLT7035 4GB NAND...
What does error message E6 mean on a prompt set spa #jl017108?
I am having the same problem, not E4 but E6 error code and have to keep resetting it and about 15 min later it start beeping the error code again? Please help
May 21, 2012 | Pool & Spa
Keep ghetting playback error message. Resetting
memroy seems to be the problem, please find a local electronics repair shop near you..
Jun 06, 2010 | Creative Labs Zen V MP3 Player
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
Digital camera photosmart r725
it wont open when power is turn on,i keep getting ,(camera has experienced an error)(please reset your camera)this number accompanies the message-00000018-4489-957-000,ive read the manuel nowhere does it say how to reset, help ?
Dec 13, 2007 | HP Photosmart R727 Digital Camera
Televison & Video Logo
398 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
