Hi J?n F?zik, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
We will need to know which password it is. Is it the Windows password used to log in to windows?Hi J?n F?zik, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
It's probably the BIOS password I changed HDD and since then I have problems switching from NB boots up splash screen boot F-9 and F-10 Bios setup and then print "Enter Current Password"It's probably the BIOS password I changed HDD and since then I have problems switching from NB boots up splash screen boot F-9 and F-10 Bios setup and then print "Enter Current Password"
You can't post conmments that contain an email address.
Right in that case it becomes quite difficult. Some bios chips are able to be reset (including password) by removing the CMOS battery, (small round button battery on the mainboard). If this doesn't work. Then the bios chip itself would have to be replaced. It may be possible to hard reset the chip by shorting certain pins but that is a big risk.
to remove your password in laptop you must remove the battery then remove the small A+ betray its inside so its dangerous to do it Give it to any PC shoe to do it
Get online
and got to www.google.com In the google search box type: "HP
Support" or "Compaq Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for manuals and search them for Bios Password or Resetting Bios Password.
Unfortunately there is no real way of unlocking a BIOS password, the only time I have been able to get into a locked BIOS was to remove the laptop battery and leave it for a few days, but that was an old laptop. New laptops will store BIOS passwords in NVRAM to stop people from being able to access it. You will need to RMA the machine to Compaq.
1) Prepare at least 1GB of USB Flash Drive
2) Download & install
A) Imgburn [Freeware]
B) 7zip [Freeware]
3) Open Imgburn > Choose 'Create image file from Files & Folder'
4) Create Image files (.iso) from Operating System CD/DVD
5) Once finished, open the .ISO files with 7zip (right click on that file > 7zip > Extract)
6) Extract .ISO file to USB Flash Drive
Note -If you are using mini laptop then make pen drive boot able to run live cds.(write "make pen drive bootable" in Google you will find a app for making pen drive boot able)
In order to change the hard drive on this laptop you are going to have the remove the battery and the keyboard because the hard drive is directly under the keys. When you remove the battery you will see 3 screws, remove them. Open the screen and flip the laptop over to see, in the battery compartment, the keyboard release access. Insert a flexible tool and press inward to release the keyboard. Flip the laptop over and gently lift up the top part of the keyboard until it releases. You will see you have the hard drive there. Unscrew it, remove the bracket and replace the hard drive. Be careful not to loose any screws and never force a screw back into place.
Clear Bios Password for HP Mini - Compaq Mini:HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a
similar [System Halted] message with 10 chars Error Code. (e.g
CNUXXXXXXX, 2MCXXXXXXX....)
