A
Anonymous Posted on Jan 06, 2014
Sharp ar m258 error h400 - Copystar Office Equipment & Supplies
5 Related Answers
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Anonymous
  • 126 Answers
  • Posted on Feb 01, 2009
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Anonymous
  • 62 Answers
  • Posted on Apr 15, 2009
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Anonymous
  • Posted on Jun 06, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
M2Tech1
Andy Bell
  • 313 Answers
  • Posted on Jun 12, 2009
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Error code h400
C-interrupt-0-interrupt-14-press print key
Sharp FO2080
C-Interrupt-0-interrupt-14 press print key
Error H4 00
This problem occurs in the Sharp copiers. Therefore pls check the fuser lamp (heater lamp) To reset this error code I need the machine model no correctly.
Sharp AR-M258 error code u2-40
l have sharp print Ar m-258
i want print front no extra
how is change setting
but show massage
(Load Extra Paper into Bypass -type(Type plan)
1helpful
Sharp ar-m206 doesnt want to enter service mode,it displays error messahe H400.What should be done to fix it?
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Sharp AR-M258 Error Code H4-20
If any one faces error H4 problem on sharp AR 258
press fast the below keys and 99.9% on the case will be solved.
1. Press #, interrupt, c, interrupt or Press #, * ,C, *
2. Enter 14, press start
wait for few seconds and it will work
Mar 22, 2011 • Cameras
1helpful
3answers
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
