SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
SOURCE: during incoming call the line will go to others extension line.
Consult an expert he will fix it bcos normally they wont let go their codes.
Rate this
SOURCE: Change Extension No's
You have to go to your phone switch, I believe that all Panasonics are modular connectors. Look for a label that will correspond to your extension number. Find your other extension and then unplug and plug.
Cheers.
SOURCE: The Panasonic KX TA824 system phone How can I make
On an 824 you only have one option, call forward busy/no answer. It means all calls transferred to that extension would go somewhere. Since an 824 has no ring groups, you can't make the system do a double hop (CF busy to 101 and if 101 is busy CF to something else) but at least it's something.
From the cordless, dial 712 1xx # with xx being the extension of the forwarded number. (710# cancels).
Carl
SOURCE: how to assign password for the extension not to make international calls
It's not a password, it's a restriction. You change the Class of Service for the phone and put in the international code as a restricted digit.
Check your Programming manual for the system.
Carl
