Kitchen Appliances - Others Logo
J
Jenny O Posted on Jan 06, 2014
How can I melt wax using a double boiler? - Kitchen Appliances - Others
Wax not melting completly
Don't know what you are talking about and it doesn't seem to be car related. This is a car forum.
tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 • Exercise & Fitness
1helpful
Repair crack in Luminara. Candle
Around the battery housing, on the bottom, you might be able to scrape a bit of the wax off. Melt the wax on a piece of aluminum foil. Depending on the length of the crack, use the melted wax and just dab around with your finger. Don't burn yourself. It'll be the same color and shade and should blend in with your current candle. Hope that works for you.
Wax in carpet
Yikes!! ok... first start by using ice to cool and harden the wax. Then use a dull knife like a butter knife to scrape as much of the wax up as possible.
Now... if the wax is an obvious color you've got a couple choices. 1. Patch the carpet with a hunk from a hidden area in the closet... OR... you can try to use a warm (not hot) clothes iron and a bunch of white paper towels to melt and absorb the wax.
See youtube for how to patch a carpet.
Mar 19, 2013 • Vacuums
1helpful
3answers
How do I remove crayon wax that melted in the sun onto my wrought iron deck table
There are a few methods. You can take ice cubes and place them on the crayon wax until it freezes. It can then be easily removed. You can also place a paper towel on the wax and use an Iron to heat the wax until it melts. The paper towel will absorb the wax. Then use a dryer sheet to remove anything left over.
Jul 10, 2011 • Garden
29helpful
Need instructions on how to use Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath -- how long to leave hands/feet in melted wax, how long to leave wax on, what to do after removing wax any...
How to fill your Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath1. Take the lid off your bath container and remove all packing materials.2. Place the unit on a flat, heat-resistant surface.3. Remove the plastic rack.4. Remove all three blocks of paraffin wax from the plastic wrapping. Each block is equal to one pound of paraffin wax, and three pounds of paraffin wax are needed to begin using your Paraffin Bath. Break each block in half, then in half again.5. Place the blocks of paraffin wax in the Paraffin Bath container.6. Plug the unit into an electrical outlet. The green light will glow. The red "Heater" light will initially come on and then cycle on and off while the wax is melting.7. Replace the lid and turn the switch to the "high" position. The paraffin wax will be ready for use when it is visibly melted (approximately 120 minutes).8. As soon as paraffin wax has melted, place the plastic rack on the bottom of the heating chamber. This will protect hands, elbows, and feet from heat.9. Turn the dial to the "Keep Warm" setting and wait 25 minutes before dipping hands, elbows, or feet.
Warning: DO NOT place hand or any other body part inside the chamber while the unit is melting the wax.
How to Dip Hands1. Remove jewelry, roll up sleeves, and thoroughly wash and dry hands. You can also rub in some of your favorite hand lotion.NOTE: The lid should be on during the time the unit is heating. Put the lid back on the unit after each use.2. Put a small amount of wax on the inside of your wrist to test the temperature.3. Spread fingers apart slightly and slowly immerse your hand in the paraffin wax container. Then immediately, but gently, remove your hand from the Paraffin Bath chamber. Let the paraffin wax solidify on your hand. Wait at least three seconds (until the paraffin wax no longer appears shiny) before redipping. Be careful to avoid touching the sides or the bottom of the Paraffin Bath chamber.4. Continue to dip your hand in and out of the paraffin wax, following Step 3, to build up layers of paraffin wax. For the best results, do this at least five times. The more layers, the longer the heat will last.5. If desired, cover your hands with glove liners and place your hands in the insulated mitts. These retain heat for better results.6. Remove the hand mitts from your hand. Remove the plastic glove and discard. Peel the hardened paraffin wax from your hands. It is recommended that the hardened paraffin wax be discarded.7. Massage in the oils left on your hand after the paraffin wax is peeled off to get the full invigorating and rejuvenating benefits of your Paraffin Bath.NOTE: Allow the paraffin to remain in place for 10-15 minutes before removing; longer if more layers exist or if the mitt has been used previously.
To Treat Feet or ElbowsFollow steps 1-4 as outlined for hands. Mitts are intended for use with hands only.
Product Care and Maintenance Place paraffin bath in a safe, cool and dry place when not in use. Wipe with a soft, damp cloth. DO NOT use abrasive cleaner. Never submerge the unit in any liquid. Keep away form all solvents and harsh detergents. DO NOT attempt to repair this paraffin bath. There are no user-serviceable parts.
STORAGEWhen not in use, "unplug it."Allow appliance to cool and store out of reach of children in a safe, dry location. To protect from dust or dirt, simply store in its original box. Never wrap the cord around the appliance since this will cause the cord to wear prematurely and break. Handle cord carefully for longer life and avoid jerking, twisting or straining, especially at plug connections.
CLEANING INSTRUCTIONSRemove plastic rack from heating chamber.1. DO NOT unplug the Paraffin Bath. Allow paraffin wax to remain undisturbed for a few minutes.2. Turn unit off and let the paraffin wax "harden."3. Right before cleaning, turn the unit on again until the paraffin wax is visibly melted around the entire edge (approximately 3-5 minutes), then turn unit off and unplug from the electrical outlet.4. Spread an ample amount of paper towels on a hard, flat, heat-resistant work surface and slowly turn the unit upside down to allow the hardened paraffin wax to drip from the chamber onto the paper towels. Allow the surface of the paraffin wax block to harden and then discard it. To clean the empty chamber, wipe with paper towels to remove any sediment.5. To clean the outside of the unit, remove any solidified paraffin wax.6. DO NOT use sharp objects to remove solidified paraffin max.7. DO NOT scratch or damage the Paraffin Bath chamber.8. DO NOT use abrasives when cleaning the Paraffin Bath chamber as it will damage the finish.9. If you discard the paraffin wax after each use, we recommend you clean out the unit completely every 40 uses. If you re-use the paraffin wax after every use, we recommend you clean out the unit completely every 20 uses.
PLEASE NOTE: This appliance should not be used in the presence of open cuts or wounds, inflammatory skin conditions, growth peripheral vascular disease where circulation is impaired, acute inflammation, or where sensation of the extremity is reduced or absent. If there is any question about peripheral vascular disease or decreased sensation of the extremities, consult a physician or physical therapist before using the Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath. Discontinue use if dermatitis due to paraffin sensitivity occurs. Discontinue use if wax feels too hot or cool, which could indicate health problems with the user.
There are also a bunch of standard warnings about dealing with electric appliances. Take care of them, don't dump them in water, etc., etc., etc.
It's worth pointing out that paraffin wax is flammable.
Can i refurbish my non stick pan. Some of my friends used a knife and made some nasty marks. can i get this fixed
At best you can recycle. Once the skin of the coating is compromised, there is little or nothing you can do to re-coat the surface with a coating such as the factory coating.
I use pans with compromised seals as a double boiler when making candles. I put my wax pot in the frying pan, fill with water, then melt my wax. I do not care of the pan gets wax on it because I no longer use it for cooking.
I also use larger frying pans pans with compromised seals under the car when I drain oil. I allow the oil to drip (provided it is less than 4 qts.) into a plastic milk container that I cut the top off of. I set the plastic container into a large frying pan that I no longer use. The handel on the pan makes it easy to slide out the plastic container once it is full of oil. I then take a funnel and transfer the oil into another milk jug or old 164 oz laundry detergent bottle that still has the threads for the plastic cover in tact. I mark it used oil and set it aside in the corner of the garage for when our community allows for the annual oil and chemical waste pick up.
My dad was an avid hunter...he used old frying pans for target practice when on the country land...he'd hang pans from the handel and shoot at the pans he hung.
Sorry this is the best I could do.
Being a mom that has gone though this enough times....I removed all my metal utensils from the drawer next to the stove with plastic ones hoping my kids would grab the closest which are now plastic that is heat tolerant.
How do i get the detergent/fab. softener tray clean? It wont drain because of the softener build-up.
Softener is a combination of wax, transport solution, and perfume.
What clogs up the dispenser is the wax.
Try pouring very hot water (close to boiling) down the path that the softener takes to get to the tub. This will melt the wax build up and wash it out.
You will need to do this multiple times to get all the wax melted.
Don't use water so hot that it melts the plastic parts.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
