SOURCE: PREINST6.SWM missing; PREINST9.SWM missing; Error:10-FC06-0002
The fact that you have an error of missing file whit the restore DVD indicate that the problem could be hardware. Especially if you already did a restore whit the same DVD.
I would suggest that you have a faulty memory issue (RAM), you can run a memory diagnostic whit memtest86 http://www.memtest86.com/ download the bootable cd and run it if you see RED readings your memory is defective if not let it run for a couple of loops to make sure.
I'm pretty shure you will see red results, if so take it to your local computer specialist to get it replace or order yourself some.
Means pre-installion is missing. Which means yoou either have to Reinstall a fresh copy of your windows or your can reinstall your windows by just repairing the files. Its always good to make a recovery disk after every install. If you haven't tried it already restart your pc press f8 as the scene pops up and go to Last good configuration.
SOURCE: HP Pavilion dv7-1240us does not restart
Press and hold the power key. It should shut down (or just pull the power).
Restart the PC and do not press the escape key
