Can't see the top settings on my Hayward pro-series settings to set it to, filter, waste, recirculate, rinse or backwash. So all I need is the Diagram Thanks from Don
SOURCE: multi-valves on hayward sand filter mixed up
Key Cover Assy needs new spider gasket. If it is a newer model the gasket is made into the key cover and it will have to be replaced
SOURCE: sand in my waste water
O-rings or gasket are replaced to stop leaks, so that wouldn't have helped you.
It could be one of two things; either the white PCV-like pipe in the filter tank is cracked OR some of the laterals at the very bottom of the tank, under the sand, has melted. A whole new underdrain assembly is usually $70.
SOURCE: I have a seam crack in s244t hayward pro series
If the tank is cracked, you most certainly need to replace the whole thing. This should be covered under warranty and the local Hayward Warranty pool guy should be able to take care of this for you. Call one of the pool supply stores in your area and they should be able to direct you to the local warranty person.
