Insttal in pc in printer & copiers online printer.
Please check
http://www.cs.duke.edu/csl/facilities/imageRunner/D129-3300.php
Hope this helps....
Canon Printer Support
SOURCE: Need for Cannon Digital Copier & Printer ir2016j driver
Please check http://www.usa.canon.com/html/download/im20162020.html
and see if the driver you are looking for is located there.Please note this is for USA models.
The Europe site is
http://software.canon-europe.com/products/0010277.asp.
Hope this helps....
[email protected]
SOURCE: I have lost my Cannon ir 330-400 pcl driver cd
Hi!
You can download the drivers needed from the link. Please select the driver you want to install from this link--
Drivers from Canon
In this link please find the drivers in the bottom.
Please rate this solution if you find this solution helpful.
Thanks
Rylee
SOURCE: Cannon-3300 Copier Error code E000-0000
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
