Question about Fossil AM3726 Wrist Watch
Need to purchases links for fossil watch - Fossil AM3726 Wrist Watch
6ya staff
SOURCE:
Anonymous
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
Anonymous
  • 109 Answers
SOURCE: I need to know how
That means you can take the links out either way. Take a small pin that fits in the hole and lightly tap on the pin. If you find you have problems, add a LITTLE oil in the whole, this should make it easier, though a little messy.
Posted on Aug 03, 2008
Anonymous
SOURCE: Watch Too Small
Extra links for your Fossil watch can be ordered by calling Metro Service Center at (800) 842-8621.
For all watches we offer up to two additional links. There is a $4 shipping & handling charge for all link orders. If more than two links are needed, you will be charged $3 for each additional link requested.
Please note that each additional link adds approximately  inch to the watchband. Link quantities are limited and are not guaranteed to be in stock.
Posted on Jan 06, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Need to remove links in metal watch band Fossil 10
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 15, 2009
Anonymous
  • 10 Answers
SOURCE: where can i get extra links for a fossil watch
go to fossil web page tell them the seriel no on back of watch and they will send u the same ones
Posted on Jan 06, 2010
I just purchased a great watch and wish to know how to switch bands since I got an extra one with my purchase
I have looked at their web site and although it is one of the most helpful sites about, it is hard to locate instructions for individual watches.
If you can't get any help from your supplier, then follow this link to reach their customer care department. They should be able to tell you how to do it. https://www.fossil.com/en_US/shop/customer_care/contactus/fossil-contactus.html
Oct 26, 2010 | Fossil AM3726 Wrist Watch
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • Aug 10, 2010 | Fossil Brown Ip Brown Rectangle Ip FS4284...
    Ihave a fossil blue watch, and need links for the band. where can I locate some?
    Contact Fossil customer care and they should be able to supply them. Here is their web address:
    http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html
    Aug 01, 2010 | Fossil Watches
    Basic Functions of Fossil FS4358
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FOSSIL watch manuals.Rate me, please.
    Mar 17, 2010 | Watches
    Need links for fossil kaleido Ll2097
    Fossil will provide you with links at no charge if the model is not too old and they have the parts.
    The 800 number is in your owners manual.
    Feb 19, 2009 | Fossil NCAA Kaleido Washington Kaleido...
    Purchase a link for a fossil link type watchband.don't have link
    My experience with Fossil has been poor customer service support for the items they sell. I could even get a flat normal crystal replaced. You can call and wait for customer service. You can also buy another one of the same model on Ebay and use the proper tools to cannibalize the links from another of the same model. You will need pin pusher tools to remove the links and replace them. Do a Google search on watch link removal to learn how this is done.
    Dec 03, 2008 | Watches
    Adding Links to Watch
    call fossil - you can order them and they come within 5-7 business days.
    Nov 16, 2006 | Fossil FS3029 Wrist Watch
    Fossil AM3726 Wrist Watch Logo
    79 people viewed this question
    Top Fossil Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ray Murphy
    john h
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
