Copier Shows only "d" symbol in Display.i tried to solve it in simulation mode with 14 error clear mode.but the problem not solved. how could it be solved.
SOURCE: Sharp AR 5316
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
SOURCE: E7 problem
Sharp AR-5132 won't print
Error code E7 13
It will warm up like it's about to print or scan then error code E7 13
please give any advice
SOURCE: My sharp copier AR-5316 E, is showing error
L4 is a motor lock if you hold down the start key it should give you a sub code 01 main motor, 11, Shift motor, Make sure all jams are cleared out of machine a jam in the fuser/heater section will cause a moter lock to clear code press key #/P-asterisk(*)-clear key(C) asterisk(*) machine will ask you to enter simulation enter (14) on 10 key pad press start,machine will reset or you may need to press CA key to make it reset. If problem comes back you will need to place a service call.
