there will be small seals or "O" rings in the pump shaft cover. Manual details will be on the net but best if you have a case technician repair it as it will be done quickly and properly.
either you have a short in the wiring, a loose connection somewhere or a bad starter, check for broken wires first and clean connections. then try the starter see if it turns with a direct connection to another battery
Pregunta , tienes, el manual de la case 580 ck, donde se muestra el circuito hidrailico de la transmision, si es asi, embiame una foto del circuito o el manual y te puedo apoyar.
